03-14-2019, 04:24 PM | #1 |
Brass cylinder heads
Would anybody know anything about a set of Mildren brass cylinder heads apparently a set has been found not far from here.
03-14-2019, 04:42 PM | #2 |
Re: Brass cylinder heads
Aussie made I believe
Gosh I were probably a teen when I saw these |
03-14-2019, 06:05 PM | #3 |
They may have been for boats. They also may be bronze. That would hold up well to salty coolant.
03-14-2019, 09:11 PM | #4 |
Pretty cool!
Hope more add!!!! My latest boat motor drool. Only because boats were mentioned. Sorry Ian. |
03-15-2019, 01:28 PM | #5 |
Interesting set of heads 21 stud shown but the casting has the provision to be 24 stud also.
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
03-15-2019, 08:24 PM | #6 |
03-16-2019, 06:59 PM | #7 |
I would guess all it would take it is drill.
03-17-2019, 05:01 AM | #8 |
only ever seen one set back in the late 70s they where on a timber boat that was doing the rounds of the show circuit no idea where they wound up
