#121 | |
![]() Quote:
You are an engineer that uses factual data to overcome theories and beliefs. Likewise my father (-who held a masters degree in Chemical Engineering) spent 30 years in the laboratory of Atlantic Richfield and later BP. Dad held several patents for both companies, and would often analyze "snake oils" to determine trace ingredients and compare to their own products. He was not alone as other oil companies had engineers doing the same thing analyzing/comparing ARCO's Graphite Motor Oil and other products to their own, so this practice is nothing new. My dad and I had this conversations more than a couple of times during his lifetime about MMO, STP, Lucas Oil Products, et/al, ...and based on their lab research there was no benefit to be gained with their usage in modern oils. To further this, Marvel Mystery Oil was invented prior to our Model-As ever even been designed, -or for that matter, before they were even thought of! Think about that and how much Ford has advanced and improved their product over the years. Why doesn't this same mindset apply to MMO? In all fairness, the MMO product likely had some sort of small benefit when used with sour crude paraffin oils of the Model-A era. Refining techniques have become much more advanced in the last 90-100 years, additives manufactured and used in modern oils has become much more advanced, and even the selections available today vs. some 50 years ago are vastly improved. So contrary to what some might still believe, any special benefit that MMO might have been to Motor Oils -or even Gasolines manufactured some 50+ years ago has most-assuredly been overtaken by modern refiners and blenders who have tailored their product(s) to meet, -or exceed any needs for using MMO in today's gasolines or motor oils. Taking an unscientific and/or opinionated survey to potentially validate something is crazy IMHO as it only spreads more confusion and misinformation. |
#122 |
I add the 4oz per 10 gallons of gas. My car always seems to run better with MMO.
#123 | |
![]() Quote:
cannot buy gasoline without ethanol added. Ethanol is the almost as bad as pouring in water to your tank. My tank is 93 years old and I will use MMO to attempt to protect it against rust. Modern oils are refined for modern cars. They lack zinc, (zddp) which is not the greatest for older engines. So, I will add MMO for the tank, and zinc for the motor.
1928 Roadster Pickup 1930 Tudor 1943 Ford WWII Jeep 1968 Taco Minibike Member, Santa Anita Model A's Arcadia Ca. |
#124 |
I would bet that if I gave one of the users of MMO 10 five-gallon fuel jugs of gas where I put MMO in only one or two of the jugs to use one at a time nobody can tell me which jug or jugs had it in the gas 😏
#125 |
My truck always run much better after I wash and clean the interior. Go figure.
#126 |
Stickshift 1915 Model T touring 1931 Ford Model AA Flatbed Last edited by stickshift; 05-26-2023 at 11:19 PM. |
