#1 |
Congratulations! I have to say that I admire your perserverance and am glad you have this finally figured out. I am in the process of installing an OD in my '51 as well and really appreciate this thread.
Happy motoring! |
#2 |
Sweet wrap up to a frustrating problem. I admire your tenacity - it paid off!
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
#3 |
Well I now have driven about 120 miles since the OD issues were solved. I can't believe the incredible difference it makes in the driving experience.
Unfortunately, one problem remains. The OD actuating cable is very stiff to operate. I don't have the original bracket that fixes the aluminum fitting near the end of the cable housing to the transmission. Proper immobilization of the housing is necessary to allow the inner cable to move freely and operate the OD lever. At present, I have used a simple cable clamp attached to the top bolt on the solenoid. This is putting the cable on a slight bind. Would anyone have a picture of ( and a potential source for) the correct bracket? I also need information as where the bracket attaches to the transmission? I did try a bracket from a '55 Thunderbird but was unable to make it work. Thanks for any help that may be provided. |
#4 |
The paper back parts catalog I have doesn't show an illustration for the overdrive control cable but a part number similar to what the Mercury cars use is listed as 8A4296. I'm not sure how it attaches since it is different than the Mercury types. They had one that was a curved metal piece that attached above the square pocket between the shift arms in a threaded hole there and used a stud with a nut to hold the cable guide. The other type was a clamp like an Adel clamp only it had an extra bend in it as a stand off and it either bolted to the same place or it bolted on with one of the side cover top bolts. The illustration is not good enough for me to tell.
A person could use an Aircraft type Adel clamp but they might have to fabricate a stand off to get as straight a position as possible with the lock out lever. I would look for one made from steel. It could take the pressure better than an aluminum one. |
#5 |
Thank you. I will research your suggestion.
#6 |
Mike Last edited by Black Fifty; 09-07-2020 at 11:38 AM. |
#7 |
That's great. I haven't found another picture of the bracket. I see that it is attached to the top bolt holding the solenoid which is where I currently have it fastened with a cable clamp. Unfortunately that puts the cable in a bind. I will try Mac Vanpelt next week. Thanks so much for posting the picture.
#8 |
I'll take a couple of pictures that show how the rest of the cable is routed from the firewall down to the trans on mine. It's a pretty straight shot to that solenoid the way it's setup.
Mike |
#9 |
Mr Laser,
I'm not a photographer for sure. But these pix may help. The cable on mine comes out of firewall and arcs down to a clip on the steering gear. The other cable is speedo. Then it passes through this tab on bellhousing. Not sure if that's correct, but the car hasn't been messed with much in 70 years (64,000 current miles). The last place the cable is held is with the clip on the solenoid shown in the previous post. No binding issues. That's all I got! ![]() Mike P.S. Thanks for volunteering to be our new R-11 Overdrive expert! Last edited by Black Fifty; 09-08-2020 at 08:01 PM. Reason: add content |
#10 |
Unfortunately we don’t have any of the various clips/clamps for securing the overdrive cable. First of all, without the cable connected to the lockout lever, check it for smooth operation. If the inner and outer cable elements are corroded (or dry) try pulling them apart and cleaning any rust off......then grease the inner cable. If the cable seems badly corroded or badly kinked, I’d recommend replacing it with a new cable. We have those in stock.
There were several locations for supporting clamps, and you’ve seen some pictures in this topic thread. Over the years I think Ford tended to change the clamp locations as well. I have some drawings from several 49-59 chassis parts manuals that I have posted a links to. http://www.vanpeltsales.com/FH_web/F..._53-59ford.jpg http://www.vanpeltsales.com/FH_web/F...49to52merc.jpg The final clamp is shown on the solenoid upper bolt in one image and it’s on an upper shifter housing bolt in another image.
#11 |
Thanks for the additional pictures and the diagrams. I had already replaced the OD cable during the restoration. The cable only binds when fixed with the cable clamp at the solenoid. I will fabricate another bracket like the one shown in the later Ford exploded view. Actually, I have enjoyed using the OD position so much that it's hard to imagine pulling that handle out. That is especially true since I live on the coast in Savannah, where things are pretty flat.
BTW, although I appreciate the compliment, I am a learning "novice" with regards to the overdrive. I give complete credit to the members of this forum, and especially Gary Duff, for all their help solving this vexing issue. |
#12 |
I am new here not sure how to do this but… my 51’ ford flathead 6 overdrive cable will not push in to engage the OD. The cable is new and shouldn’t be the problem. Also, after a lot of finessing I was able to push it in and the OD did engage so it isn’t electrical. Since then I have pulled the cable back out for fear it won’t go back in. Can anyone help me out? Thank you
Matt |
#13 |
Hi Mjmiller1967, and welcome to the Ford Barn.
I experienced a very stiff new cable in a 1950 Ford when I added overdrive. In my case the dash bracket was bent and binding the cable. Did you test the cable for easy movement before installing it? Have you lubricated the cable after installing the housing? A 51 Ford with a six and overdrive will be a nice car to drive, let us know how this goes for you. Also, I suggest you start a new thread introducing yourself and your car. You will probably get more attention with a new thread than at the end of this old thread. |
#14 |
While you have it apart do a very almost surgical cleaning of the planetary gear pack. On one side there is a tin shield with a grove behind it . This is the oiler for the little needle bearings in each planetaty gear and it gets micro particals packed in it. I use a dental pick and a tooth brush then air . I've done more of these OD's then I can remeber and clean is the key to having the work perfect for years and miles to come. Tim
