Old 05-22-2020, 03:11 AM   #101
jrvariel48
jrvariel48's Avatar
Default Re: Opinion on PCV valve for flathead?
Which PCV valve are you guys using on your set up??
jrvariel48 is offline   Reply With Quote
Old 05-22-2020, 09:51 AM   #102
glennpm
glennpm's Avatar
You need to pick a PCV valve made that is close to your engine displacement. I use one for a 1990 Plymouth Voyager 3.0L or 181cid, V6. The number is PCV333. I went smaller and this works well for me. No oil mist on firewall and didn’t affect my carbs. I have two 97s and 269cid on a 59A.
Old 05-22-2020, 03:36 PM   #103
jrvariel48
jrvariel48's Avatar
Great! Thanks, I'll have to do a little searching!
Old 09-27-2020, 02:11 PM   #104
eicke
Any pics of this install? Just wonderin' which direction the PCV goes.
eicke is offline   Reply With Quote
Old 09-27-2020, 03:00 PM   #105
glennpm
glennpm's Avatar
Yes I do! Also look at this post listing a horizontal mounted PCV for a small block Chevy, if you want a larger one than I used:
https://www.jalopyjournal.com/forum/...#post-12322077
Glenn
Old 09-27-2020, 04:06 PM   #106
eicke
Thanks, Glenn! I thought about drilling the manifold in the same spot as yours as mine also has access in tis location.
Old 09-27-2020, 05:31 PM   #107
glennpm
glennpm's Avatar
Good, glad I could help you!
Old 09-29-2020, 09:36 AM   #108
markdtn
markdtn's Avatar
The vacuum port just below the carb on an iron 8BA intake uses 7/16 banjo threads. I bought a GM disc brake 7/16 banjo bolt and a 7/16 banjo to 3/8 hose barb fitting (AKA 12mm banjo x 10mm barb). I am using a Motorcraft EV68 PCV valve and a Dorman/Help 42052 Grommet in the road draft hole.
markdtn is offline   Reply With Quote
Old 09-29-2020, 03:20 PM   #109
1948F-1Pickup
1948F-1Pickup's Avatar
My port below the carb (iron factory 8BA intake) is 3/8-18, which is NPT dimension. Just installed a fitting with a 1/16" nipple to run vacuum hose to a "Delco" distributor.
Maybe those manifold ports aren't just one size.....
1948F-1Pickup is offline   Reply With Quote
Old 09-30-2020, 01:27 PM   #110
blucar
blucar's Avatar
The vacuum ports on most EFV8 intakes are generally 3/8" to accommodate vacuum for the distributor advance and wipers. The vacuum to operate the Columbia OD is tee'd into this port which is located below the rear carb on my Offie Super manifold.
Generally the engines for the larger trucks have a larger vacuum port to accommodate the vacuum assisted brake booster and/or 2spd rear axle.
Bill.... 36 5 win cpe
