#61 |
Close up
#62 |
Maybe it is just me; but that doesn't look very good. Did you try adjusting the box before taking it apart to see how worn the gears were?
#63 |
I did not payed much so I can get new parts inside.
I has not struggle with old steering box before, but its just this ’dent’ and the rest look fine and it did turn around fine ( I never try to test adjust it ) as it was cut out of frame part so I had several hours just get nut lose and steering arm off and it was oil and dirt all over so it had a fast swim in the bath. When I look at the crack/dent it look as it could been in material before grinding. As its hardneeded so is it normal that gears crack like this ? I dont think more parts come off, but again steering box gears has not been on my table before. I can get gasket/schims and test how it feels before I bought parts. This coupe I’m into is huge in all corners try get all part and try to set the style. Last edited by 3W Hank; 06-04-2024 at 05:39 PM. |
#64 |
When one use a F-1 box I hear its not that great in a chopped coupe as a steering will get a ’bus wheel feeling’.
I will use a Auburn 32 dash but use upper part 32 so dash will be lower, so what is benefit just lower steering shaft, vs a std or Hudson or a F-100 box. In this 3W coupe with a F-1 I think the angle look Ok ( or ? ) ( One can rotate and drill new holes in frame ) |
#65 | |
![]() Quote:
#66 |
#67 |
Stock interior dimensions for your comparison
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat's Notes Techno-Source-for-the-1932-thru-1953-Flathead-Ford |
#68 |
I has to see when body is back and sofa is there, how it feels.
I will use the std package tray behind seats. I dont need sit perfect but arms to much above will feel strange. I don't know how much angle will change from std/F-100/Hudson vs the F-1 n reality. One thing, I do like the deal use Ford and from 48, fits me perfect plus I like the look on that box. |
