Old 05-20-2021, 07:03 PM   #61
Ranchero50
Thumbs up Re: High Compression Head Review
Originally Posted by BRENT in 10-uh-C View Post
While I agree that a camshaft change along with an increase in compression and increased air-flow all compliments each other, however because most Model-A camshafts are worn, my experiences have been that a cam change wakes up performance more than a higher compression head does if you can only change one thing.
I was kind of surprised that while swapping the head I checked the valve travel on mine and most were @ .030" less than original from wear and lash. The seats and valves looked decent. The pistons were wobbling in the bore though.
Building a '29 Speedster, the hard way...
Ranchero50 is offline   Reply With Quote
Old 10-01-2021, 06:33 PM   #62
Tom Foster
Default Re: High Compression Head Review
Originally Posted by Jim Brierley View Post
My head hurts!!!
(Insert smileys here!)
Tom Foster is offline   Reply With Quote
Old 10-02-2021, 10:47 PM   #63
old ugly
old ugly's Avatar
i am glad to see that you went with the OD transmission when your objective was to travel at a faster speed with lower rpms.
changing the cylinder head will give you more horse power but it will not change your engines rpm at a given higher speed.
rear end ratio, tire height, transmission output ratio, and an overdrive unit are the sort of things that give you a faster speed at a lower rpm.
the cylinder head will help you get to that speed easier and to maintain that speed easier on hills.
so don't let someone tell you that you can travel faster continuously just by changing an engine component. the engine will still be running at higher rpms and you better make sure the Babbitt is good.
my 2 cents
old ugly is offline   Reply With Quote
