Old 10-24-2018, 10:49 PM   #1
Cape Codder
Cape Codder's Avatar
Default Re: Terriable backfiring
30 Closed Cab PU Thanks for your response. I was thinking the same thing about the gasket BUT I have to get the head off before I can report how it looks.
saintjoelarry Well I haven't taken the muffler off yet. It is an Aries Stainless Steel (put on new 11,000+ miles ago) although I'm sure that doesn't matter. Thanks for your response also.
Ernie Vitucci Thank you also for the comment and suggestion.
Corley Thanks for your response and also a great explanation!!
I will make comments when I get the head off. I also plan on checking the valve clearances while I'm at it. Then I will see if either the blown gasket? or the valves being out of adjustment caused the backfiring which I'm not really convinced it is. If not I will have to continue on with the trouble shooting.
Cape Codder is offline   Reply With Quote
Old 10-25-2018, 11:00 AM   #2
Cape Codder
steve s It is too late as the engine has been drained of water, water pump is off and all bolts to head are loose. Problem is head won't come off so I have ordered a head puller which hopefully will be here Saturday. When I get it back together I will try your suggestion.
Old 10-25-2018, 11:12 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Start soaking all the studs with Kroil ASAP.
Old 10-25-2018, 12:09 PM   #4
steve s
steve s's Avatar
Did you try just turning the engine over with the starter after backing off the nuts just a few turns?
steve s is offline   Reply With Quote
Old 10-25-2018, 12:30 PM   #5
30 Closed Cab PU
Tom and Steve have great ideas. Even if you have previously tried Steve's suggestion but not Tom's, do Tom's and try again. You can actually run the motor. As the head lifts the distributor/cam shaft should raise with the head, and immediately shuts off the motor.
I had a particularly stubborn head, the mechanic tried this method, did not have a puller, tried using a motor hoist and had the front end off the ground, had to resort to soft wedges. Ends up there was so much rust from sitting for 50 years with a bad gasket he was not sure a puller would have worked.
30 Closed Cab PU is offline   Reply With Quote
Old 10-25-2018, 01:27 PM   #6
Cape Codder
Tom Wesenberg I have been soaking the bolts to no avail. I have had 5 - 6 bolts come out and all are unrusted maybe because they are chrome molly bolts.
steve s that was the first thing I did and the rear lifted just a bit! I'm done using the scraper and waiting for the puller. I also tried some HARD WOOD WEDGES but that also didn't help.
I installed the head gasket myself some 11,000+ miles ago which was the NEW head gasket at the time i.e. with the RED sealant around all the bolt holes etc. and believe the gasket itself is holding the front of the head down.
Old 10-25-2018, 01:31 PM   #7
Cape Codder
I forgot to acknowledge 30 Closed CabPU for his response. You can see above my response.
Also thanks to Tom Wesenberg and steve s for your suggestions and response.
Old 10-25-2018, 03:45 PM   #8
1crosscut
1crosscut's Avatar
The puller will help get the head off. They work pretty well. Once the head is all the way to the top of the head studs it will not be able to lift it any farther. You can then attach a engine lift to the puller and use that to get it the rest of the way off if it still needs help. Be careful though if you do because the head can separate pretty suddenly causing damage the junction box or firewall etc...
Another option is to make spacers out of 1/4' nuts by grinding the tips off making them round. They will then be able to sit on top of the four head studs the puller pushes against and have room to recess into the head. Sometimes several need to be stacked on top of each other to get a head all the way off.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 10-26-2018, 08:32 AM   #9
katy
katy's Avatar
That's probably what's holding the head on.
Old 10-26-2018, 09:09 AM   #10
30 Closed Cab PU
I have not seen additional sealing around the bolts mentioned before in my short time as a Barn member. Is this recommended, and if yes why?
Old 10-26-2018, 09:44 AM   #11
cpf240
cpf240's Avatar
Perhaps to keep any water leaks from rusting the studs?
cpf240 is offline   Reply With Quote
Old 10-26-2018, 11:06 AM   #12
Benson
Default Re: Terriable backfiring-Another Reason to use antifreeze.
Reason number 27 to use antifreeze.
Simple solution to rusted stud problem is to use antifreeze mixed with the water!!
Just sayin ....
Benson is offline   Reply With Quote
Old 10-26-2018, 01:17 PM   #13
Cape Codder
30 Closed Cab PU The gasket that I have on the engine right now is pictured below, hopefully ...........but is listed in Snyders P/N A-6051-M. Sorry didn't work, but check it out in Snyder's catalog online listed under Parts on the home page of this site.
cpf240 That is the reason I used it but............now I have questions because I really think that is what's holding it on.
Benson I have been using antifreeze in the motor ALONG with DISTILLED WATER. As I said the bolts that have come out attached to the nut don't have any rust on them.
Old 10-26-2018, 01:27 PM   #14
30 Closed Cab PU
No need for the picture, I was asking you and the others the purpose of sealing the bolts, and if it is recommended. By the way you do a great job of responding to everyone, I really appreciate that.
Old 10-26-2018, 01:45 PM   #15
CSPIDY
CSPIDY's Avatar
Backfire= fire out the carb usually caused by ignition problems
Afterfire=fire out the exhaust usually caused by valve; timing, leaking or burnt
CSPIDY is offline   Reply With Quote
Old 11-02-2018, 10:30 AM   #16
Cape Codder
Just an update on my problem. As I had said we opted to pull the head. We bought the head puller from Brattons but to be truthful, I was disappointed in its operation. The #7 bolt which works with the puller was not as accessible as to other three to get a wrench on. The wrench was hitting on the high spot of the head because of the tunnel, for a lack of a better word, that goes forward to the water pump, and also the fitting supplied that goes in the #1 spark plug hole. We, therefore, decided to pull the remaining bolts from the head, with #7 giving us considerable trouble.
After getting the head off we observed that the gasket between #3 & #4 was intact. This was the reason we removed the head as the compression check showed 48lbs. in #3 and #60 in the rest of the cylinders. We also had done a blowdown test which showed air coming from #4 and when we put air to #4 we had air coming from #3. These two tests indicated to me that the head gasket was blown.
I will check the head for straightness today and if needed take it to the machine shop and have it ground. Wonder how much is left to take off?
As always any comments would be welcome relating to this latest event!
Old 11-02-2018, 11:55 AM   #17
heneste
heneste's Avatar
If the head is straight and not the issue with the compression loss, would a poor valve seat, bent valve or sticking valve let air from #3 to #4 and vice versa?
heneste is offline   Reply With Quote
Old 11-02-2018, 04:28 PM   #18
Cape Codder
30 Closed Cab PU Thanks for the compliment! I try.
heneste Thanks for your response. I just returned from the machinest and he declared that the head is in fact FLAP! However, in the same breath, he said I should have it planned because he saw some spots that were too ruff into the head.
As to determining if there is a poor valve seat or bent valve I don't know how to determine that. After cleaning up from the head removal i.e. cleaning the gasket off I will get into checking the valve clearances sooo...if there is anything wrong I should be able to determine that.
Old 11-02-2018, 09:59 PM   #19
steve s
steve s's Avatar
gonna be a heck of a note if the problem was a plugged jet in the carb.
Old 11-02-2018, 10:05 PM   #20
Fred K-OR
Fred K-OR's Avatar
X2. I agree.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
