12-18-2016, 05:57 PM | #61 |
Re: Pulled my spare engine apart for inspection
I did end up bolting it on to the engine and soldering it in place. I hadn't realized how far out of line the two cupped ends really are. I used silver bearing solder and flux for potable plumbing. It didn't flow as well as I'd hoped, but it came out OK. It seems very strong.
12-19-2016, 06:28 AM | #62 |
Art, I am going to go out on a limb here and say your engine will probably be a leaker. The reason is the groove to the front of the rear bearing. This groove is not necessary and will let combustion gasses and piston pressures to force oil to the rear of the bearing and overwhelm the slinger and return tube causing the well to leak into the flywheel. If it does, you can call me and I will tell you how to remedy this problem. I would post it but it may be controversial and I don't want to cause trouble on the board, I can tell you and you can convey the message.
12-19-2016, 10:48 AM | #63 |
quality soldering job, Art; it flowed nicely
'31 180A |
12-19-2016, 12:15 PM | #64 | |
12-19-2016, 12:18 PM | #65 |
12-19-2016, 03:33 PM | #66 | |
Using the valves on #4 to get TDC on #1 is a system as old as 4 cylinder engines used around the world, except your place apparently. I'll explain it to you again in a PM if you like.
I'm part of the only ever generation with an analogue childhood and a digital adulthood. Last edited by Synchro909; 12-19-2016 at 03:54 PM. |
12-19-2016, 05:26 PM | #67 | |
01-12-2017, 01:19 AM | #68 |
My engine made the trip to the test stand today...
01-12-2017, 10:16 AM | #69 |
Wishing you the best start up of all and thanks for this thread Art.
01-12-2017, 11:19 AM | #70 |
01-17-2017, 04:37 PM | #71 |
Tomorrow is D-DAY!
01-17-2017, 09:57 PM | #72 |
Good luck I'm betting she's going to run great!
01-17-2017, 11:14 PM | #73 |
Fingers crossed! I'm pretty sure it will run, the starter is untested, I moved manifolds/carb from my running engine so they are a known good quantity. I can always pull the starter if I have to. Worries are unseen cracks/waterleaks...
01-18-2017, 04:17 PM | #74 |
Here's the setup, need a better fuel line arrangement.
01-18-2017, 04:19 PM | #75 |
This is the third run, was getting hot just about to shut it down. I have some video start to finish that I need to look through and edit.
https://www.youtube.com/watch?v=FEdXISGwGac |
01-18-2017, 04:21 PM | #76 |
Just a word on using the jumper cables.. many look beefy but when you cut open the thick covering youll find the cable is puny.. they are designed to assist starting using another cars battery..
just mentioning in-case you get a slow crank... |
01-18-2017, 04:22 PM | #77 |
Art, I bet you had a smile a mile wide when it fired and ran.
I noticed that you don't have a clutch fitted. Normally, the final balance of the crankshaft is done with flywheel and pressure plate fitted. What are your plans here?
01-18-2017, 04:23 PM | #78 |
Just my own thoughts, but I certainly wouldn't be running MY engine without coolant of some sort, even for a short while.
01-18-2017, 04:25 PM | #79 |
If you look close, you'll see there is a battery cable in there as well. It's a 12 volt one... all I had on hand. The engine was very tight and we had a very slow crank so we paralleled it with the jumper and it helped a lot.
01-18-2017, 04:27 PM | #80 |
