07-23-2015, 07:52 PM | #61 |
Re: Secret Tips
But not as much fun, heh.
07-23-2015, 10:16 PM | #62 |
Re: Secret Tips
Watched an Old Western, Jimmy Stewart poked his finger in a guys' gun barrel & said, "If you shoot me, that thing will EXPLODE & blow your HAND off"!!!
Bill W.
07-24-2015, 04:30 AM | #63 |
Re: Secret Tips
If it's running well leave it alone and don't screw it up by twiddling with the points or carburetor until it doesn't run at all. About the only thing I do is check the gas sediment bowl for dirt and clean it if necessary.
07-25-2015, 10:30 AM | #64 |
Re: Secret Tips
When tightening or loosening a rear axle nut, take a 2 or 3 foot piece of flat or angle iron, drill a 1/2" hole near one end, put it on one of the wheel studs, brace it against the next one w/the other end on the ground.
I use the same practice when working on open driveshaft vehicles when R&Ring the pinion nut.
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 07-25-2015 at 10:37 AM. |
07-25-2015, 10:36 AM | #65 |
Re: Secret Tips
Here's a pic of my "tool trolley". It's a flat wooden box about 12" x 12", I picked it up about 30 year ago, put 4 casters on it. I use it when working at floor level like on brakes or under a vehicle. Keeps all the tools and small parts corralled.
YMMV
07-25-2015, 10:44 AM | #66 | |
Re: Secret Tips
(available @ HF free on occasion) http://www.harborfreight.com/6-in-ma...der-61428.html |
07-25-2015, 11:13 AM | #67 | |
Re: Secret Tips
Also, IF you work over a cement pit, paint its' walls APPLIANCE WHITE & you WON'T even need a DROP LIGHT! Bill W.
07-25-2015, 11:32 AM | #68 |
Re: Secret Tips
That is great idea!
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
07-25-2015, 11:45 AM | #69 | |
Re: Secret Tips
07-25-2015, 06:08 PM | #70 |
Re: Secret Tips
trk overheating, today drained coolant,engine pans in pristine shape.lined pan with alum foil to catch in a bucket.worked great & could see particals coming out with petcock slightly open. added rad flush & will do again this week.don't think I would see particals on my black pans.vinagar next time if not satisfied. tom
07-27-2015, 08:31 PM | #71 |
Re: Secret Tips
WARNING!!!! WARNING!!!! WARNING!!!!
Under NO circumstances should the suggestion in response #57 be attempted (using the 22-cartridges). You have absolutely no control over pressures that could develop. I hope everyone can see the danger this could be.
Ron/IA 1929 Fordor Steelback Hawk A Model A Ford Club http://hawkamodelaclub.org/ |
07-27-2015, 09:13 PM | #72 |
Re: Secret Tips
I have found a few tools that help me time my rig. Not being an expert in this area, I find these tools get my timing as good as I need it. They are the ratchet nut wrench: http://www.brattons.com/product.asp?...=any&PT_ID=all
the quick set point setting tool:http://www.brattons.com/product.asp?...=any&PT_ID=all and the timing cam wrench tool:http://www.brattons.com/product.asp?...=any&PT_ID=all I take the top off the distributor and hit the starter until the rotor is about at the #1 pin. Then I use the ratchet nut wrench to get the timing pin at exactly TDC (this wrench make it easy rather that using the crank). Then I use the timing cam wrench tool to get the cam set the way it should be at #1 pin. Then put the rotor back on to check how it lines up with #1 (the way the books say you should have it). Then I take the rotor off again and use the quick set point setting tool to set the points. I find this tool will set the points at about .22 which I like for a new set of points. So hope this helps someone other than me. Yes it does cost a bit in tools but this is a lot better than having you A run bad because you can't get it in time.
Fred Kroon 1929 Std Coupe 1929 Huckster |
07-28-2015, 02:30 PM | #73 |
Re: Secret Tips
I am not trying to rain on any party.
Just trying to save a life! I have been a reloader for over 50-years, and have seen what over-pressure can do.
