02-22-2013, 05:59 PM | #41 |
Re: Yes, they are still out there!!!
Wow , what a score . Great looking car .
T |
02-23-2013, 04:12 PM | #42 |
Shadetree, Don came up today to give the car a once over, it did get his approval, will continue to clean up and order some parts on Monday to go for a start up soon.
THUMBS UP!!! |
02-25-2013, 04:49 PM | #43 |
Sent Model 48 carburetor and fuel pump to Ken in CT to re build. fuel pump needs ethanol resistant internals and a new 9" fuel hose. Cleaning up generator and waiting on new fan belt, radiator hoses and vacuum hose to distributor, go for a start in couple of weeks, Bruce
02-25-2013, 08:03 PM | #44 | |
02-25-2013, 08:12 PM | #45 |
I can get you his number from the v8 book Bruce.,call me tomorrow or tonite.don p
DON P |
02-25-2013, 09:08 PM | #46 |
Post number of flex hose supplier so everyone can have info, thanks Bruce |
02-25-2013, 09:52 PM | #47 |
Boy Oh Boy you lucked in there Brucy
02-25-2013, 10:12 PM | #48 |
Damn the luck
02-25-2013, 10:46 PM | #49 |
No phone number. E- mail gadgiteer@ aol.com $28 for no ck valve $38 for c valve ppd
DON P |
02-26-2013, 03:27 PM | #50 |
Very classy car
02-26-2013, 07:14 PM | #51 |
Photo of 1934 intake ( high generator mount and diamond fuel stand hole ) after I cleaned up, do not know of reason why intake was patched. After 79 years I believe several of us have had patches done, cars are no different???
02-26-2013, 09:24 PM | #52 |
jon wright's custom chrome in grafton ohio can replate the grill, just did one for me ,super job.
02-27-2013, 08:21 PM | #53 |
nice nice nice.
What dates are on the oil change labels on the door? My'33 Cabrio has one from '69. |
02-27-2013, 09:55 PM | #54 |
They say 1982 and 84!!!
Today took the generator/fan assembly to Don's and we disassembled and cleaned up all the parts, Don is painting the parts, I had to leave to purchase a new bearing to replace the old bearing that required grease/oil. Not any wear problem yet but was dry, replaced with a sealed type bearing. Also, started to pick at the intake right below the weld patch with a straight screw driver, opened up a hole about a 1/8" x 1/2" long. The intake alumiun was as thin as an egg shell. Looked at another intake Don had that was weathered and it already had a hole corroded in the same spot as the location on the 34 intake. Took intake to welder friend of mine and he is going to close, will continue to look for a better 34 intake, Bruce |
02-27-2013, 11:19 PM | #55 |
JB weld would have worked & a bit less expensive on the intake repair.
02-27-2013, 11:42 PM | #56 |
subscribed to this post looking foward to seeing a video of it running...nice find!
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford |
02-28-2013, 05:19 PM | #57 |
Don and I reassembled the generator today, ran test on the generator to see if it would motor, passed that. Next we hooked up the multi-meter and ran generator to see the voltage, everything worked well and then placed fan on generator. Checked out all the old plugs, all worked well.
Generator Complete Generator Motoring Test: http://youtu.be/qLkOSOwqDfc Generator Voltage Test: http://youtu.be/PkA5H460_SU Spark Plug Test: http://youtu.be/93G_SmJkRXo Last edited by Bruce in southern OH; 02-28-2013 at 09:14 PM. Reason: adding link |
03-01-2013, 09:39 PM | #58 |
What's that rusty bar for between the front fenders? Fog Lights........or....
03-03-2013, 07:27 AM | #59 |
Removed the water pumps from heads, has signs of slinging grease on the back of pulleys. Who has pumps, looked at Drakes and they are only 37 and up, who has early water pumps, they look so simple, very clean inside, turn free with just a little resistance as you would expect, is there a way to test for leaks, do not what to reassemble and have water going every where after 30 years of setting. I did clean up with solvent out of parts washer, brush only, will paint after I find out if they need attention.
Before cleaning |
03-03-2013, 11:28 AM | #60 |
Being that you have them off send them to skip in Fla for rebuilding. You'll be happy you did.
