Old 10-28-2013, 07:54 PM   #41
28ACoupe
28ACoupe's Avatar
Default Re: Model A Engine Cooling
Time to revisit this. *bump*
1928 Model A Business Coupe
Rebuild picture gallery here
The light at the end of the tunnel has been turned off due to budget cuts.
28ACoupe is offline   Reply With Quote
Old 10-28-2013, 08:43 PM   #42
Mitch//pa
Originally Posted by columbiA View Post
I admire your plans to re-restore your coupe,but if it was me ,I think I would find a similar car & use your interior & top kits in it,especially if the body is warped out of shape.Of course,nothing is impossible-All it takes is time & money!
columbia called that one
Old 10-29-2013, 01:00 AM   #43
racer32
http://www.globalindustrial.com/p/hv...Fejm7AodSWUA5A
Might save you propylene users a few bucks.
I'm thinking I can afford to keep using distilled water and cheapo ethylene glycol for quite a while..."lifetime" products generally aren't.
racer32 is offline   Reply With Quote
Old 10-29-2013, 01:12 AM   #44
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
I'm sorry but was there question not answered?
Old 10-30-2013, 08:03 AM   #45
Ice man
Ice man's Avatar
Well I ran my 29 Pk Up with a warmed up B engine, NO fan and a 32 V8 water pump and the rad was a Walker made for pressure. Also this truck was in St.Thomas,VI. with a lot of REAL heat. The engine NEVER ran hot, even in traffic. Iceman
Ice man is offline   Reply With Quote
Old 10-30-2013, 09:53 AM   #46
tbirdtbird
the guy says he is not a salesman for Evans, but he sure sounds like it !!!! ya coulda fooled me !!
It is a cover-up. The 'other ppl on the side of the road' have some kind of mechanical issue that needs to be fixed, not covered up by a coolant that boils at a million degrees. They need a re-core, adjust timing, get that danged front license tag out of the way of the rad, get rid of the leaky head gasket that is allowing exhaust gas into the water jacket, etc, etc.
Why am I able to drive around Texas all summer without that stuff??
'31 180A
tbirdtbird is offline   Reply With Quote
Old 10-30-2013, 10:03 AM   #47
Mitch//pa
right on
Old 10-30-2013, 12:19 PM   #48
Purdy Swoft
Purdy Swoft's Avatar
Just because its not boiling doesn't mean that its not overheating. Modern vehicles have pressurized cooling systems that are designed to run at higher temps. Unpressurized cooling systems loose coolant out the overflow tube as heat expands . No coolant will be forever in an unpressurized system. I will continue to use water as a coolant in my model A's. I would only use antifreeze in freezing weather in my model A, if I had to drive it.
