Old 11-09-2013, 11:01 AM   #1
Purdy Swoft
Purdy Swoft's Avatar
Default Re: Speedster Kit
Here is my home made speedster. I'm a po country boy and couldn't afford the kit. I had a bunch of discarded parts and decided to try and make a purty out of them.
Old 11-09-2013, 12:07 PM   #2
Mike
Mike's Avatar
Skrain,
Thank you, we have a lot of fun with this car
mike
Mike is offline   Reply With Quote
Old 11-09-2013, 08:08 PM   #3
QGolden
QGolden's Avatar
Mine started as speedster, and I decided to fab my body rather than buy one I started with the chassis in my avitar, took 3 springs out of the rear, 2 out of the front, re rolled the front springs to turn the eyes over., and used 17 inch wheels. It sits a few inches lower all around, and has about 3 inches of rake to the front. Admittedly it is morphing into more of a Rod than a speedster though.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain.
It is the very things that we think we know, that keep us from learning what we should know.- Unknown
QGolden is offline   Reply With Quote
Old 11-10-2013, 09:39 AM   #4
Skrain
Skrain's Avatar
Some questions for anyone who has done a Rootlieb speedster...can you buy the modified spark and throttle controls you need to install?
What is involved in repositioning the pedals?
Where do you get the resized steering arm?
"They can make me grow older, but they CAN'T make me grow up!"
Skrain is offline   Reply With Quote
Old 11-10-2013, 12:35 PM   #5
Sparky
Sparky's Avatar
I have a little homemade bell crank linkage that is attached to the top of the engine.
There is no need to change the brake and clutch pedals. For the gas I am using a Fulton pedal with a linkage about four inches long.
Cut the original and weld in an extension section as required.
Sparky is offline   Reply With Quote
Old 11-11-2013, 08:09 AM   #6
QGolden
QGolden's Avatar
Originally Posted by Sparky View Post
I have a little homemade bell crank linkage that is attached to the top of the engine.d
That is what I did to, I turned a ring that fit over a head nut, made a small divot in the nut for the head of a screw to fit into, and made a Bell-crank that attached to the ring to transfer the linkage over the head. Locknuts and loctite seem as though it will keep in place.
I guess you can simply bend the Spark Advance rod. Most sane folks do, but I really do not like the looks of the bent rod. I used a throttle rod set to each side of the Bell-crank.
Old 11-10-2013, 09:49 AM   #7
Mike
Mike's Avatar
Howie,
That is a beautiful car!!!
Mike
Old 11-11-2013, 08:36 AM   #8
slackcat
slackcat's Avatar
Looks great howie.
slackcat is offline   Reply With Quote
Old 11-13-2013, 08:12 PM   #9
howie123
howie123's Avatar
The color is called Cactus green. It was a Ford pick-up color from the 70's. The fenders and splash aprons are black. Hood, fenders and trunk are pinstriped in red to match the wheels. Ford script on the gas tank is also matching red. I extended the spark and throttle linkage by cutting in the middle and making a sleeve to go in between. The spark linkage had to be bent for clearance. I was not able to make the pedals work by bending alone. I had to cut them and weld in a piece to extend them. The drag link was cut and a piece welded in to extend it the same amount the steering box was moved.
howie123 is offline   Reply With Quote
Old 11-13-2013, 09:14 PM   #10
QGolden
QGolden's Avatar
Thank you Howie for the additional information. You did a nice job on it, feel free to post additional photos or a photo album. If possible, I would appreciate seeing more of it.
Old 11-14-2013, 08:29 AM   #11
Wallace
.great combination of design and skill... thanks to all
Wallace is offline   Reply With Quote
Old 11-14-2013, 05:47 PM   #12
Brother Hesekiel
Brother Hesekiel's Avatar
If you want to see a sharp Model A Speedster, look here:
http://www.themotoringjournal.com/fe...speedster.html
Brother Hesekiel is offline   Reply With Quote
Old 11-14-2013, 11:13 PM   #13
BCCHOPIT
BCCHOPIT's Avatar
I can't find anything I don't like about this one.
I have many pics of this one saved to my laptop
WAC that banger in the A$$ and drive it home hard
http://waccustoms.com
BCCHOPIT is offline   Reply With Quote
Old 11-15-2013, 08:00 AM   #14
Ross/Kzoo
Ross/Kzoo's Avatar
That #7 is one sharp speedster. Are there more detailed pictures of that car? I like the way that the body seems to fall below the frame. I wonder if he widened the frame to get seating for 2 in the cockpit. More detail would be appreciated.
Ross/Kzoo is offline   Reply With Quote
Old 11-15-2013, 10:32 AM   #15
BangerMatt
BangerMatt's Avatar
Originally Posted by Bill O'Brien View Post
How about some more pics of Speedsters!
Speedsters are fun, here are some pictures of a couple that my father and I have built together. The first was a partially built Rootlieb kit where the folks building it "lost some parts". We took it apart and redid it the way we wanted to, using a '40 Buick hood for the tail.
The second is the red one, built from the ground up using a "hot rod cast-off" chassis using a '41 Ford hood for the tail.
BangerMatt is offline   Reply With Quote
Old 11-15-2013, 02:00 PM   #16
George D
George D's Avatar
Just wondering, what goes between the plywood deck and the frame on these kits? Is there some form of crossmembers or spacers of some sort?
George D is offline   Reply With Quote
Old 11-15-2013, 03:10 PM   #17
BangerMatt
BangerMatt's Avatar
The kit that I disassembled just had something like a welting material in between. Nothing substantial. The rear plywood had been cut to allow the hump of the rear crossmember through.
Old 11-15-2013, 07:25 PM   #18
howie123
howie123's Avatar
Q Golden, Thanks for the comments. I am attaching a few more pictures. Howie.
Old 11-15-2013, 08:32 PM   #19
Sparky
Sparky's Avatar
Hey Howie, is that Ford logo on the gas tank a decal or a custom job?
Old 11-15-2013, 11:02 PM   #20
QGolden
QGolden's Avatar
Thanks for the inspiration! Where does your Starter Rod go? It looks lengthened and is a a high angle.
