07-06-2022, 07:31 PM | #41 |
Re: Engine temp rises when I get to cruise speed
I'll say it out loud. The "cheap Ebay aluminum P.O.S." radiator cooled your engine, but the fancy expensive Brassworks unit did not. Why are you going to the ends of the earth trying to make the Brassworks unit work? After reading all of this, it's obvious that the Brassworks unit is inferior. Live with it it.
07-06-2022, 07:45 PM | #42 |
Another option is to temporarily remove the fax and shroud (if possible). Then don't spend any time idling, but take it out on the highway and see what it does at cruise speed. You don't need a fan on the highway - so this will answer the question as to whether or not that assembly is constricting flow through the radiator at highway speeds.
Best of luck. On the jets, go 2 numbers up . . . surely won't hurt anything! |
07-06-2022, 09:06 PM | #43 |
I'm sure you have addressed the timing as it was running cool with the previous radiator.
Do you have more pictures of the car as a whole. Sounds like a great one. Best of luck! Looking for the, "Ah I got it post!" Man I love this shiz... if you are a motorhead and never been to a nhra event. Seriously.. https://www.youtube.com/watch?v=03Ybyq6osNY . Last edited by Tinker; 07-07-2022 at 01:59 AM. |
07-07-2022, 12:47 AM | #44 | |
B&S's idea to pull the fan and shroud and hit the road sounds like a good test. I don't understand one of those two tube aluminum radiators working better than the same size 3 core brass radiator. Be interesting to see how this all shakes out. |
07-07-2022, 02:23 AM | #45 | |
Secondly, it's not costing me anything to do that. Third, I need to prove to Brassworks that it is their radiator that's at fault so I could possibly get some no cost repair work or credit. (don't know if that's possible) If that's not an option I just threw $1200 bucks in the garbage or I have to pay someone to fix it. The ebay radiator was installed out of necessity until the Brassworks unit was built. While it worked, it's not something I want to keep in my car. The search continues! Thanks Joe |
07-07-2022, 02:29 AM | #46 | |
Two jet sizes is not a problem at all. Thanks B&S |
07-07-2022, 02:30 AM | #47 | |
Thanks Joe |
07-07-2022, 02:35 AM | #48 | |
I'll try to post a picture but I'm not to good with that stuff! I'm waiting for that post also!! I've been going to see top fuel NHRA racing for over 30 years!! There really is nothing like it! Standing next to those monsters in the pit when they fire them up is one of the highlights of my life!! I'm a nitro junkie for sure!! Thanks Last edited by jrvariel48; 07-07-2022 at 02:35 AM. Reason: Spelling |
07-07-2022, 08:02 AM | #49 |
The radiator people explain it this way: Fin contact with the tube is how the heat is taken from the water. Copper /brass radiator tubes are about 5/8" and are oval in shape. Aluminum tubes are 1"-1 1/4" and flat on the sides. There is much more fin contact area on the aluminum radiator.
07-07-2022, 09:07 AM | #50 |
I didn’t know that! I always thought copper was better
Thanks for the info. Joe Last edited by jrvariel48; 07-07-2022 at 09:07 AM. Reason: Spelling |
07-07-2022, 09:12 AM | #51 |
It'll be interesting to see if Brassworks "steps up" if you can prove their radiator to be deficient.
07-07-2022, 09:22 AM | #52 |
I've spoken with Lee at Brassworks and am/was planning to have them make a custom radiator for my 34 coupe (has a big off-topic blown 392 Hemi in it). The engine will make about 800 HP on the street - and HP creates heat!
I'm sure interested in this thread in that cooling is super important and the radiators that Lee supplies are surely on the higher end of the price scale - so they better work! If this turns out poorly, then I will have to go to another custom radiator manufacturer. |
07-07-2022, 01:46 PM | #53 |
07-07-2022, 01:47 PM | #54 | |
That sounds like one hell of a motor!!! |
07-07-2022, 05:39 PM | #55 | |
The lower grille pan is an important part to direct air flow. Air comes in the grille, and if the lower pan is missing, air will take the path of least resistance, exiting below the radiator. Your radiator itself offers a large resistance to air flow, and with the shroud, even more. At higher speeds, the different air flow ratio is multiplied. Without further changes, take a test run with the lower pan installed. On another subject, copper is most definitely more heat conductive than aluminum. (If money were no object, silver would cool more efficiently than would copper). The size, number, and configuration of tubes and fins being the same (which they are not), Brass tanks with copper tubes/brass fins are superior to aluminum in everything but the initial cost of materials/labor, and there's your reason aluminum is used in modern applications.
Alan |
07-07-2022, 10:44 PM | #56 | |
At least I know why I paid so much for the radiator! It is a beautiful piece, but it needs to work too!! Thanks Joe |
07-08-2022, 11:30 AM | #57 |
I recommend using thermocouples rather than temperature gauges because they are more accurate. The thermocouple wires could be inserted under the hose clamp and bent over at 90 degrees to be in the center of the flow stream. Some multimeters have a thermocouple setting to read the temperature directly or you can read the voltage of the two wires and convert to a temperature.
07-08-2022, 05:29 PM | #58 | |
07-08-2022, 07:46 PM | #59 |
No reason to reinvent the wheel temp gauges will work perfectly to help determine what's going on.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
07-09-2022, 05:54 AM | #60 | |
Thanks Ronnie |
