#41 | |
![]() Quote:
#42 | |
![]() Quote:
Numbers are for illustrative purposes only. lets say you have 6V at the battery. You use a resistor to knock that down to 4V at the coil. You engage the starter the starter pulls the battery voltage down to 5V lets say. The resistor drops that 5V to lets say 3.5V at the coil. Hard starty. So lets put in a diode or relay to bypass the resistor when starting. Starter pulls battery down to 5V Coil gets full battery volts which is 5V and more than the normal 4V. That's better than 3.5V. Easy starty. Mart. |
#43 |
>>>So lets put in a diode or relay to bypass the resistor when starting.>>> Starter pulls battery down to 5V Coil gets full battery volts which is 5V>>>
The relay yields 5v. The diode only yields 4.4v cuz it needs ~0.6v forward bias to make it conduct. Easy starty only if there's a decent spark. 8^) |
#44 |
So can it be safely said that the "bypass with a diode" approach is ONLY effective on a ignition system which has a resistor in line to the coil but does NOT have a resistor bypass incorporated in the starting system. I believe this is where the confusion comes in the discussion.
#45 |
Hang on partners. We're are talking about two different sources in different posts.
rockfla is saying two batteries in post #41. Mart I think, is using one battery, correct? |
#46 | |
Don T That's the way I see it. This would be for a 12 volts system. With a single battery 6 volt system you don't need a resistor in the primary coil circuit to keep the point spark down. |
#47 |
>>>With a single battery 6 volt system you don't need a resistor in the primary coil circuit to keep the point spark down.>>>
Yes & no. Yes. No resistor needed with 6v coil. No, Resistor needed with 4v coil. 8^) |
#48 | |
![]() Quote:
#49 |
I was describing the principle used in a stock type situation that uses this sold start bypass system. One battery with the bypass normally provided by the starter solenoid.
#50 | |
![]() Quote:
Personally I'm a 12V guy and all my cars use a 12V coil, no resistor and no need for any fancy bypass circuitry. Mart. |
