#41 |
And a young engineer at Ford in the late 90s, called a rachet a "socket thingy"..........
#42 |
Here's one that I can't understand... A lot of people who should know better insist on calling the diesel engine in their dodge a Cummings. And about half of them call it a 'Cummings Motor.' perhaps these folks were influenced by the works of ee cummings?
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) Last edited by GB SISSON; 02-17-2022 at 08:23 PM. |
#43 |
I was inspired by the work of Clessie Cummins
#44 | |
![]() Quote:
#45 |
Actually, a threaded fastener with threads that taper to a point is a screw. A bolt has the same size threads all the way down.
#46 | |
![]() Last edited by tomcarman; 02-18-2022 at 12:34 AM. |
#47 |
#48 | |
![]() Quote:
8BA heads are held on with cap screws. If it screws into a threaded hole in a casting it is a cap screw. If the same fastener is used with a nut it becomes a bolt and nut. To most mechanics they are all bolts, Bill |
#49 |
#50 |
Thunderbolt
Lightningbolt
Alan |
#51 |
Stovebolt Oh no, a Stovebolt is a Ch---
#52 |
Anyone refer to the couch as a Chesterfield?
That said steel is iron. It is not cast iron. The difference I believe is the amount of carbon. Now angle iron needs to be spec'd also. What size and thickness, and it can come in stainless steel which also contains iron. Got this from google. Show it to your engineer. Steel is an alloy of iron and carbon. It can contain small quantities of silicon, phosphorus, sulfur and oxygen. The carbon content of steel is between 0.08 to 1.5 percent. This makes it harder than wrought iron but not as brittle as cast iron.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
#53 | |
![]() Quote:
#54 |
Tires have T-R-E-A-D-S…..your clothes are held together with T-H-R-E-A-D-S…… this one has always bugged the bejesus outta me….Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver…RIP |
#55 |
But when my older son was in college in Seattle, he and 5 friends piled into a Russian kids' 500 dollar oldsmobile cutlass and drove to Mexico for spring brake. A few months later they came to Orcas Island in the olds and I had never seen such bald tires. They didn't have any tread, but there were 'threads' sticking up where the tread should have been. As I made a remark about the tire I ran my hand over the top of the right front, only to find they were the needle sharp, now hook shaped steel belts and of course I was swiping against the grain. Now if it was an old style tire it would have had threads. Cotton, rayon, nylon. Sorry to be a smartass!
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) Last edited by GB SISSON; 02-18-2022 at 11:34 AM. |
#56 |
Originally "water pump pliers" were so named because they were designed for tightening the packing nut on early water pumps such as the Model A.
#57 | |
![]() Quote:
And.....this T-H-R-E-A-D is beginning to get a little long in the tooth. DD . |
#58 |
I watch a lot of youtube machining channels and adding a t to across to make acrost seems very common.
#59 | |
![]() Quote:
Cheers, Jim&Sandy McGregor, IA |
#60 |
Never heard Chesterfield other than cigarettes but I use davenport and couch as synonyms.
