Old 07-24-2015, 01:00 PM   #41
RobertB
RobertB's Avatar
Default Re: Oil Filter
Originally Posted by Bob Bidonde View Post
Katy,
It's a FRAM XG8A 1HP. Google it for a source and check eBay.
Bob, that's just the filter...what about the remote mount gizmo?
RobertB
Santa Teresa, NM
RobertB is offline   Reply With Quote
Old 07-24-2015, 08:44 PM   #42
CarlG
CarlG's Avatar
Looking at Snyder's oil filter kit, it appears that filtered oil bypasses the valve chamber where the crankshaft and camshaft bearing oil feeds are. Is this so?
Originally Posted by Harley03joe View Post
What Do You Guys Think Of The Timing Side Cover Filter ?
Model A Oil Filter Kit
The plate mounts on the front of the engine where the timing side cover is. Easy to install with no modifications at all. U.S.A.
From Snyders Antique Auto
A-6705 $99.00 / ea.
1928-31
Please Let Me Know Ok
Thanks
Harley03joe
Post #7 quotes an article in the Model A Times that says this filter is "ineffective". It only filters a small portion of the oil, and sends it to the timing gear, bypassing the oil chamber.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 07-26-2015, 01:38 AM   #43
Harley03joe
Harley03joe's Avatar
CarlG
This one
Bob This Is What Rod Wrote About That Filter Set Up
ROD Post #7 >>> The second filter kit reviewed was the “Timing Gear Cover” partial flow and I do not know if this system is still sold. But the review by “Model A Times” stated “ineffective”.
Now What Bob ???
Harley03joe
Harley03joe is offline   Reply With Quote
Old 07-26-2015, 10:47 AM   #44
katy
katy's Avatar
Found it in my 1990 Fram catalogue, P/N HPK2
http://www.amazon.com/Fram-HPK2-Spin.../dp/B000CBSFUE
Old 07-27-2015, 11:39 AM   #45
Harley03joe
Smile Re: Oil Filter
Question:
What Are The Pro's And Con's On Installing An Oil Filter ?
Should It Be Done On A 31 Ford ? And Why Didn't Ford Put One On The 31
4 Cyl ?
What was the first car fitted with a replaceable cartridge oil filter?
Answer It Was The 1924 Chrysler.
I Wonder Why Ford Left That Important Part Off There Cars ?
Maybe Some One Can Elaborate On This Subject
Thank You Harley03joe
Old 07-27-2015, 12:02 PM   #46
mrtexas
mrtexas's Avatar
Ford was cheap cheap cheap
mrtexas is offline   Reply With Quote
Old 07-27-2015, 12:09 PM   #47
Harley03joe
Ha Ha Thank You For The Answer
BUT Not The One I Was Looking For
Harley03joe
P. S. The 31 Is Not Cheap Any More
Old 07-27-2015, 03:02 PM   #48
1931 flamingo
1931 flamingo's Avatar
If you're following the "guidelines" and changing every 500 mi or so you probably DON'T need a filter. JMO
Paul in CT
Old 07-28-2015, 09:07 AM   #49
katy
katy's Avatar
In 1955 a friend of my older brother won a new Pontiac (Canadian) in a draw, that car was the cheapest Pontiac available, 6 cylinder, no oil filter, no radio. You paid extra if you wanted those options.
Old 07-29-2015, 12:14 AM   #50
Harley03joe
Paul in CT
I See The Word PROBABLY & Might >>> Not Good Words
Thank You For Your Info
Harley03joe
P. S. I Added Might
Old 07-29-2015, 08:40 AM   #51
bdave_mcc
bdave_mcc's Avatar
Still been researching the oil filter thing. For anyone that was looking for it. Here is a remote mount from summit 20 bucks part number prm-1211
bdave_mcc is offline   Reply With Quote
Old 07-29-2015, 08:42 AM   #52
bdave_mcc
bdave_mcc's Avatar
Do any of you guys know if the valve cover can be welded on? Trying to come up with a leak free entry for the oil back into the valve chamber
Old 07-29-2015, 09:53 AM   #53
katy
katy's Avatar
Bob, in post #8 said:
removed the valve cover and drilled and tapped it for 1/8th inch pipe threads
Sounds like a good solution to me.
Old 07-29-2015, 10:16 AM   #54
bdave_mcc
bdave_mcc's Avatar
Yeah I can do that but i need a fitting of some sore on the inside of the valve cover to get the oil directed the right way. In the original system the oil is blasted frontward out the dump tube and splashes forward all over the place. I need to replicate this as I will be plugging the stock dump tube. I would like to weld an elbow or something to the inside of the cover.
Old 07-29-2015, 10:56 AM   #55
CarlG
CarlG's Avatar
I would think that just dumping it anywhere in the first chamber would be sufficient. That's what the "A-Ford-Able" filter does.
Alaskan A's
Old 07-29-2015, 11:33 AM   #56
bdave_mcc
bdave_mcc's Avatar
You're right, I just want to cover all my bases so I can end up with a best possible scenario situation. I definitely want to filter the oil for my new engine...don't want to blow it up either
Old 07-29-2015, 09:21 PM   #57
bdave_mcc
bdave_mcc's Avatar
Ok Carl. I just want to be clear. The a ford able filter literally just dumps the oil straight back into the front chamber? Nothing fancy going on...That makes things easier for me. Probably just over thinking it.
Old 07-29-2015, 09:29 PM   #58
denis4x4
denis4x4's Avatar
Just removed an A-Ford-Able filter with a remote canister that can be used with headers. Had to cut the tubing to remove it, but it can be made to work. Includes original instructions. Pay the FedEx ground fees and it can be yours for free! PM me.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 07-29-2015, 10:43 PM   #59
denis4x4
denis4x4's Avatar
It's gone! No more PM's please.
Old 07-29-2015, 11:24 PM   #60
updraught
updraught's Avatar
So how does the oil line plug into the block?
updraught is offline   Reply With Quote
