Old 11-24-2018, 10:58 PM   #41
160B
160B's Avatar
Default Re: Cold weather driving with or without thermostat?
The two 1/4 inch diameter, (r=0.125) holes have a total area of .098 SQ IN
The one 0.43 inch diameter hose (r=0.215) has an area of 0.145 SQ IN
So the 0.43 hose has about a 50% larger opening than the two 1/4 inch openings
https://www.bing.com/search?q=area+o...24c4f823d08781
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 11-28-2018, 11:55 AM   #42
steve s
steve s's Avatar
The commercial 'stat housing has bypass holes machined into it. In my prior arrangements, I supplemented with two 1/8" drilled holes. Also, have heater hose for bypass (without metering valve, but with shutoff valve for summer use). Years ago, used cardboard when A was my daily driver: what a PITA. I was sooo happy to discover thermostats!
I think the "thermal shock" business is one of those things that sounds good if you say it fast, but otherwise is a bunch of hooey.
File Type: jpg 2010 radiator replacement 001 cropped.jpg (74.7 KB, 41 views)
File Type: jpg 2010 radiator replacement 002 - cropped.jpg (63.5 KB, 40 views)
steve s is offline   Reply With Quote
Old 12-03-2018, 01:19 PM   #43
DHZIEMAN
For the weather in my area, I do what was done originally. A cut a piece of thin plywood or cardboard, about 1/3 rd of the radiator for the limited driving I do! I do understand we are all different and those that add a thermostat, is fine. Just not for me!
DHZIEMAN is offline   Reply With Quote
