Zenith |
68 | 60.71% |
Tillotson |
11 | 9.82% |
Marvel Schebler |
29 | 25.89% |
other |
4 | 3.57% |
Voters: 112. You may not vote on this poll |
#41 |
Sorry , I've got it now . The bold print at the top of the thread
#42 |
#43 |
#44 | |
![]() Quote:
This carb finally solved my rough running problem after pulling up to a stop light on a hot day after a long run. Also, I can't stall the motor no matter how hard I hit the brakes. Previously, I had used several rebuilt Zeniths and a brand new repro Zenith 1. |
#45 |
Location: Barren windswept mountain somewhere in bleak Northeastern Pennsylvania
Over the decades whenever an A Model Ford was acquired, at first opportunity, the Zenith would get pulled off and some other functioning carb get put on. Wasted too much time early on trying to get those design defective Zenith things to properly function and not stall on excess fuel. This current car came with a rebuilt Zenith that was dripping gasoline all over the place and flooding out. Got rid of it ASAP.
Used Tillys mostly back in the old days. Now employ a re-manufactured Marvel carb and that 31 sedan is the best running Model A I've ever owned. No problems!
I wouldn't be so paranoid if people weren't plotting against me all the time Last edited by Capt Quahog; 02-17-2018 at 10:35 AM. |
#46 | |
Ken, Also, although the carb was sold by that outfit in Washington, it was still manufactured by a Zenith factory in New Jersey. I once spent a long, pleasant time chatting with the factory's customer service rep trying to figure out an engine surging problem I was having, before I realized it was due to my Parkinson's tremor in my foot! For some reason, even though this model is sold specifically for Model A useage and is made by Zenith in the USA, the carb still doesn't get no respect. The same core is apparently also used for a variety of industrial applications and used to be disparaged as the "fork lift carb." |
#47 |
My vote is for a restored Zenith Carb. It is what came with the car. Be sure that when you rebuild the carb, you use jets that have been flow tested to the required specs. Get the carb rebuild manuals by Rex Reheis and Steve Pargeter. For years I rebuilt carbs only to be disappointed in the car performance. The reason was incorrect flow through the jets. Ed
