Old 03-20-2017, 09:57 AM   #41
1931flathead
Default Re: t5 transmission in my 1953 ford 2 door
Thanks jseery
1931flathead is offline   Reply With Quote
Old 03-20-2017, 10:49 AM   #42
rick r
rick r's Avatar
You will probably find that the shifter location on the S10 trans is the most suitable for your 53. I used the standard S10 in my 51, the shifter is in the ideal location
rick r is offline   Reply With Quote
Old 03-20-2017, 11:15 AM   #43
1931flathead
I thought it would be to far forward
Old 03-20-2017, 05:51 PM   #44
1931flathead
What kind of adapter did you use in it thanks
Old 03-21-2017, 05:44 PM   #45
1931flathead
Pictures of the car
Old 03-22-2017, 06:55 PM   #46
1931flathead
thanks jseery
for your help I found the problem I need a new input shaft some one cut it of about a 1/2 inch my splines will be a little short buy less then a 1/4 inch they should be ok like that
I went and took a tape to a 1952 3 speed so I know for shure what I need for that part just got to get the right clutch disk
Old 03-22-2017, 07:06 PM   #47
JSeery
JSeery's Avatar
Ft Wayne will custom make a clutch dish for you if need be. http://fortwayneclutch.com/
Old 03-22-2017, 07:13 PM   #48
1931flathead
speedway sell disk I probably have to take it apart to get the right one could be 9 1/2 or bigger
Old 03-22-2017, 10:12 PM   #49
Richard in Florida
Richard in Florida's Avatar
Originally Posted by JSeery View Post
Ol Ron here on the Barn has helped with this T5 installation and should be able to provide the needed information. Believe it was Richard in Florida's car. Flat Ernie is another source. My experience is with the Hogsheads type of bellhousing adapter and no experience with the later style of bellhousings.
In my '53 Victoria, I used an Astro Van rear section because it put the shifter in just the right place. The S10 put it too far forward, and the Mustang put it under the edge of the front seat.
I used a Ford input shaft and a 2.95 gear set with a 0.7 5th gear.
In conjunction with a machined aluminum plate adapter, I used the stock bellhousing, stock flywheel, stock clutch, stock throwout bearing, stock pilot bearing, and a readily available clutch disk for a Mustang II.
Everything worked perfectly and the car was a pleasure to drive, as Ol' Ron can testify.
Photos available.
Richard in Florida is offline   Reply With Quote
Old 03-22-2017, 11:05 PM   #50
Ol' Ron
Ol' Ron's Avatar
It was a very simple and inexpensive instillation. Once you have the right transmission.
Old 03-23-2017, 10:05 AM   #51
1931flathead
Thanks guys gust got to get couple parts then I be OK doing it
Old 03-23-2017, 10:38 AM   #52
Ol' Ron
Ol' Ron's Avatar
Richard, you should post a pic of your instillation.
Old 03-23-2017, 02:50 PM   #53
1931flathead
Richard I thought the s10 would be to far under the dash I was thinking using a Camaro tail shaft housing and top
Old 04-16-2017, 03:38 PM   #54
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by 1931flathead View Post
what ever
So........How is the T5 transmission swap coming along? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 04-16-2017, 03:46 PM   #55
1931flathead
I'm going to swap out rear axle instead of the transmission found a Granada rear axle cheep
Old 04-16-2017, 04:34 PM   #56
1931flathead
I don't dive mine very much after I had my surgery my arm heart a lot when I drive it got to wait un tell my arm get better
the only part I need for my s10 is a hub for the throw out bearing unless could find one would work with the stock arm other wise it will fit with the right clutch plate and pilot bearing
