#1 | |
![]() Quote:
Here-here ! You want to get the engine up to full operating temperature, and KEEP IT THERE, for at least 20 minutes once or twice a week. This helps "boil" condensation and unburned fuel blow-by out of the oil. Also the exhaust system. If you do a mostly short-trip driving, I would also suggest installing a 160* thermostat in the upper radiator hose. This will help get your engine to operating temperature quicker, and make for happier running / longer life. SAE (Society of Automotive Engineers) defines "short trip driving" ( where the engine never reaches operating temperature, or doesn't stay there for at least ten minutes or more ) as "severe service" when it comes to oil change intervals. |
#2 | |
![]() Quote:
Thank You;
Brian French; 1930 Briggs Town Sedan |
#3 |
I might have missed it but did anyone say fire extinguisher? anything other problems are minor
#4 |
#5 |
Wow, this thread kind of makes me laugh.
Chapter One: I bought my first model A from a neighbor who drove it to work every day. It was a wired together POS but it kept running. I bought it for parts and used it to play Pan American Road Race in the hills of South Pasadena, CA. I tried hard to kill it and never did. I had to dismantle it and throw the parts away. Even the parts continued to have life. Chapter Two I bought a POS Model A on eBay, went through it and drove it around a while before putting in a rebuilt motor. There are times of the year I drive it every day. In 2015 I went with a horse group down the Pony Express Trail. Over 2000 miles mostly on dirt roads. Two days before we left I said to my wife "I think I'll load the Model A on a trailer and drive it around during the trip". By the time we got to St Joe and I had a few beers to think things over I decided it would be really cool to see if I could drive all the way to CA. All I needed was for someone to drive the truck and trailer. I made it into Nevada when the old coil gave out. I picked another off a rusted old junker in the desert and continued the trip. Chapter Three When I come back south after 6 plus months in Alaska I go to start my cars. The only one that starts every time, with no excuses is the Model A. These are the closest things to bullet proof you can own. The main spares you need are found in the fences along the way as long as you have a piece of matchbook to work on the points and a Leatherman to fix anything else. PS Drove it to Alaska and back in 2012. I did take a spare distributer which I didn't need and had an alternator come apart in Canada. I fixed that with wire and a borrowed bolt. If you don't drive the hell out of your Model A you are missing one of the great experiences of motoring life. |
#6 |
I don't know about Sarasota, but here in the Ft. Lauderdale area signals are worthless at best and dangerous at worst.
#7 |
I added a "slow moving vehicle sign" to the back of mine for a little added protection that stands out visually. Other cars can come up on you real fast.
#8 |
Would also highly recommend an LED strip-light, such as the one from "Logo-lites" (?, "Brakeliter"?), mounted in the rear window. It is an LED array about 1 inch high by about 12 inches long.
It is fairly unobtrusive when not lit, and can be attached in a non-damaging manner to the car ( I made some clips there are secured by the interior garnish moulding.). This unit can be wired to function as full-width stop, or Left-half / Right-half turn / Full width stop, depending on how your vehicle is set-up. The advantage is that mounting in the rear window puts the bright LEDs right up in the sight-line of most modern drivers. It's hard to ignore. Even if you brighten the OEM stop/tail light with LEDs, their small size and low placement may be not noticeable to modern (distracted) drivers. Last edited by Special Coupe Frank; 01-04-2017 at 11:09 AM. |
#9 |
The guys only talking about a four mile trip!
I agree- just wing it! and........... get yourself the basic triple A policy in case you ever need a tow. around 60. |
#10 |
I totally agree. For a four mile trip many of the suggestions are very excessive. I was expecting to see, lease a tow truck and put it on standby. It's four miles, get on with it. Wayne
#11 |
Thank you very much! This sounds easy enough.
Thank You Very Much;
#12 |
The tools you will need will always be the very ones you left on that workbench in your garage.
I drove the wheels off my '30 tudor as a daily driver and work vehicle for years before selling it. I didn't treat it as a trailer queen, nor did I shelter it from the elements. I pretty well drove it just as the originals were sold from the dealerships and meant to be driven. I drove it in Owensboro, KY, Iowa Park, Tx and Arlington, Tx so I pretty well had all seasons covered and found some uniqueness to driving in the 4' snow in Owensboro in the dead of winger vs the hotter 'n hell summer temps in the Wichita Falls area. I ran out of gas a few times, but there was always some good soul who came by an helped, most often because they spotted the unique auto and really just anted to be around it. No other major break downs to speak of for me, but I did have a fuse blow out a few times on the starter to it. I was lucky I suppose. A funny experience, but a brow shorts moment, was when I had stuffed a shop rag into the hold on the cowl for that manifold heater to be inserted. It was winter and I didn't have the manifold heater, so I stuffed that red rag in the hole to block the air there. Later I was driving to work when I noticed smoke billowing out under the dash and gas tank like a run away bar-be-que smoker. A corner of that rag had touched the muffler and caught on fire. I was all over the road in trying to stop out that fire with my leg extended across the seat and trying to stop the vehicle at the same time. Stupid human trick #4,501 for me, but I did get it out and only had a brown shorts moment from the experience and not a Darwin award in killing myself. Any rate, the best thing to worry over in using a Model A for a daily driver is the other guy. Lights or no lights, you really have to do defensive driving at all times to remain safe. Not everyone behind you will respect the idea that it is a vintage car or that it does not do the super slabs at 90 miles per hour. Not everyone is attentive and not everyone is always in a "take it easy" mode as they drive. Give the other fellow room to act the fool and never let someone else rush you into making a turn or a stop any quicker than you really should. Side roads are not always any safer, but look out for the other guy no matter what type of road your traveling on. Speed is not your friend in going to work or just driving it as a daily driver about town. Me, I ran into problems in using it to go to work as I always had a delay if I stopped. People wanted photos or wanted to ask questions or wanted to make comments. I got called outside by folk to chat about it and sometimes even my staff pulled me out to show the car off to their friends or ask about it. That didn't always make my boss happy and when I became a school nurse in Arlington, I simply couldn't drive it to the elementary school I worked at, as the kids would have been all over it and at all times of the day. I made that mistake in taking my sidecar rig to school a couple of times and it was hectic in just keeping the kids away from it. I suppose I can lie or stretch the truth when I get my '30 pickup running again and try to drive on my insurance policy and vintage tags which really say I can only take it to shows, parades and ice cream parlors. Not sure I want to do that though, but it is not my main daily driver these days like my ole tudor was. Oh, well, interesting to see what others can't live without in using their A as a daily driver. I had a 12 mile run to work each day and I learned to never take off fast (and I mean even a slow fast speed) with ice on the road and stopped at a red light. The tail will pass your front end if you speed off like a bat out of hell in ice. Torque is an interesting item. :-) It was funny in Owensboro, Ky, as I got to work every single day in the dead of winter and in snow as high as a foot in my '30 tudor, but a lot of folk, even with 4 wheel drive vehicles, could not get past their front driveways. Sure wish I had a manifold heater back then though. That little upside down moon shaped area that my 6" windshield wiper always slung the ice from side to side on in clearing was always a challenge to see out of when driving. Good luck to you in what you decide to do and what all you find necessary to make it a more dependable vehicle as a daily driver. Lots of interesting thoughts and opinions here. I guess I am just a minimalist, but my times in running out of gas were some of the fondest memories of my old '30 tudor I had. Nice folk always came to the rescue. |
#13 |
[QUOTEThat is an interesting tow bar. Did you build it? How does it attach to the A?][/QUOTE]
Years ago a friend had a tow bar that clamped onto the front bumper bars. We used it for pulling quite a few cars, including Model As, worked slick.
#14 |
As some one who drove there model A as there daily driver and only car for 4 years though hot summer days and New England blizzards putting about 150 miles a day on it I have some good insite on this topic. The reality is most of you who break down do so because your cars just aren't driven enough the more you drive an A the stronger and more reliable it gets once you dive the bugs out of it (the bugs the ocational trip doesn't shake loose) they really are bullet proof. My biggest break down was I had a water pump seize up on me once on a 3800 mile road trip; and believe me my truck was far from being in mint condition.
I recommend a good set of tires. And extra point plate all set up and an extra condenser. Rainx is good and don't forget to use your hand signals turning. Adding the second tail light helps incase a cop with no knowledge of older cars stops you. All these modern things like led lights and lap belts just give you a feeling of being better of but really aren't. Cops have both bright blue lights and they still end up road kill during a tragic stop. And in regard to the 6vt system, iv had plenty of alternators let me down dead on side of road. It those old gens go out slowley and tell you there going. You'll I find in our As the 6 by system works just fine if it doesn't it's becouse your car has a problem. My repop aluminum nitrate reflectors with original incandescent bulbs and reflectors work the balls on 6vt much brighter than my 12v salvaina sealed beams in my Jeep Wrangler that are (also relayed) Drive it and have fun and remember if something on the car is not up to par it's not cuz the system isent good it's because your cars not right. My model A was the most reliable car I've ever had oh btw keep a pair of nilon stockings in your car in case you ever lose a fan belt or water pump tie from crank to gen and go. The water pump realy Isn't needed when driving only sitting at red lights on hot days. And one piece of information that was given to me by Keith True on here) that has never let me down (99% of all carberator problems are electrical) ![]() |
#15 |
Be sure to carry "SNAKE OIL" with your spares!--It comes in a corked bottle--NEVER know when you'll encounter a SNAKE!!
Bill Prepared
#16 |
Hi Smoothy,
I used a large screw driver to bend the clamp a little. The armor cable id still in position, but just finger tight. It looks original, but you can pull it clear if need be. Enjoy your car.
Regards Chris Cape Town 28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC |
#17 | |
![]() Quote:
#18 |
