Old 09-04-2016, 04:50 PM   #1
somethingspecial
somethingspecial's Avatar
Default Re: Horn Help
My horn on my 28 special coupe did the same thing its shorting out on the horn part , its a very small fiber or insulated washer , on the u shape part that holds the carbon thing with the scree. You have to look very carefully it might be missing it ,should be four of them each side of the u shape piece .
somethingspecial is offline   Reply With Quote
Old 09-06-2016, 03:22 PM   #2
JerMar
JerMar's Avatar
Well thought it was the brake switch but it's not. Got the horn back hooked it to the battery and it sounds pretty but still getting the sparks when trying to hook the wires to it from the cutout. I am getting 6V from battery to starter, from starter to terminal box (left post), goes to the ammeter and back to right post of terminal box and then to the cutout. From the cutout to the horn is a cnstant 6v on the yellow wire that goes to the horn. The blue wire that goes to horn there is nothing. Should there always be power (6v) going to terminal and to cutout and to horn?
JerMar is offline   Reply With Quote
Old 09-06-2016, 03:43 PM   #3
Bob C
Yes. The blue wire to the horn is grounded when you push the horn button.
Bob
Old 09-06-2016, 03:45 PM   #4
JerMar
JerMar's Avatar
Bob
So there should always be 6V from the yellow wire at the horn terminal? Or should there be 6v when you press the horn button?
Old 09-06-2016, 03:51 PM   #5
Bob C
[QUOTE=JerMar;1350269]So there should always be 6V from the yellow wire at the horn terminal? Or should there be 6v when you press the horn button?[/QUOTE
Yes, there should ALWAYS be 6V at the yellow horn wire.
Bob
Old 09-08-2016, 11:33 PM   #6
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Look at the drawing, The horn has only two wires. One wire comes from the battery and one goes to the horn switch. That's it. If the horn switch is grounded the motor will spin. If it is not nothing should happen.
Take a picture on how you have the wires connected to the horn.
It is VERY hard to assist when we cannot see that is being done.
Have YOU taken the horn wiring off and used a battery charger to test the horn? I don't care what the repair guy did, did YOU do it?
I know you have said before that hooked up the charger to the horn and it only got hot and did not blow. There can be only 2 reasons for that, you are not hooking it up correctly or the horn is defective. That's it only those two things. If you cannot get it blow with the wires disconnected and a battery charger connected all the rest of the wiring in the car means nothing.
Is there anyone near Richmond Va. that can help him?
Old 09-06-2016, 03:47 PM   #7
Bob C
This link has the same wiring diagram that Mike posted but you can blow
it up to see the yellow wires better.
http://modela.webjunk.com/technical/...wiring-diagram
Bob
Old 09-06-2016, 03:51 PM   #8
JerMar
JerMar's Avatar
Bob
Yes, I have looked at this wiring digs gram for hours and everything is right.
Old 09-06-2016, 04:19 PM   #9
Bob C
Ok. Take the three wires off the output side of the cutout now touch the wire from the terminal box to the cut out, does it spark? If yes the problem is in the cut out/ generator, if no leave it hooked up to the cut out. Touch the yellow wire from the horn to the cut out output, does it spark? If yes the problem is in the horn, if no leave it hooked to the cut out. Touch the yellow wire from the light switch to the cut out output, does it spark? If yes the problem is in the lights, if no sell the car.
Bob
Old 09-06-2016, 05:08 PM   #10
tbirdtbird
do you have a friend who is good with electrical things?
'31 180A
tbirdtbird is offline   Reply With Quote
Old 09-07-2016, 02:01 PM   #11
captndan
captndan's Avatar
I still think there is a grounding problem. Grounding means the positive side. The negative side of the battery goes directly to the starter switch. The starter is grounded meaning positive. Somewhere there is a negative wire that is grounding. Confusing ain't it?
captndan is offline   Reply With Quote
Old 09-07-2016, 09:36 PM   #12
JerMar
JerMar's Avatar
Yes I believe so to but I have went through everything and can't find it!
Old 09-07-2016, 10:25 PM   #13
tbirdtbird
see if a local club member can help you
'31 180A
Old 09-09-2016, 05:06 AM   #14
bobusnick104
bobusnick104's Avatar
I agree with Alan. I had installed a cover screw that was too long and it shorted immediately.
It's only money, we'll make more tomorrow.
bobusnick104 is offline   Reply With Quote
Old 09-21-2016, 06:24 PM   #15
stewwolfe
stewwolfe's Avatar
A couple of us went over to JerMar's house yesterday and looked at the situation. He wired everything correctly! We pulled the horn off the car (thereby isolating it from the ground) and it worked properly. When I checked the terminals on the horn I discovered that there was continuity to the horn frame, so he had a constant short. I told him to send it back to the rebuilder. It will work fine using a battery charger in this configuration, but will short out when connected to the frame of the car.
'31 40B
'31 68C
stewwolfe is offline   Reply With Quote
Old 09-21-2016, 07:41 PM   #16
tbirdtbird
thanks for the follow up
'31 180A
