Old 08-25-2016, 02:56 PM   #1
Charlie ny
Default Re: Need help to set idle
I kind of see gaskets or washers under the jets too ,BIG no no....no gaskets or washers
under main jets.
I do hope you find the 'V' style nozzle bars.
Failing the above try blocking the small vent hole that you see in the nozzle bar
adjacent to the idle tube.......this would be under the category of experimenting.....
so do not do this on a permanent basis. This worked for me one time a long time ago.
Charlie ny
Charlie ny is offline   Reply With Quote
Old 08-25-2016, 03:06 PM   #2
david.skinner
david.skinner's Avatar
Good eyes Mart - they are little black gasket seal thingys (not sure what they are called). they are soft - not washers. They came with the carb kit but it doesn't mean that I have it right. thanks.
D.
david.skinner is offline   Reply With Quote
Old 08-25-2016, 03:08 PM   #3
david.skinner
Oops - charlie thank you - none under the idle side of the spray bars either?
Old 08-25-2016, 05:52 PM   #4
Mart
Mart's Avatar
The thin black gaskets go under the spray bars, both sides, 4 locations, like you have them.
Mart.
Old 08-25-2016, 05:58 PM   #5
FlatheadTed
FlatheadTed's Avatar
I think you would have some back firing if your MF gasket was gone ,I would try another carb .Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 08-25-2016, 06:14 PM   #6
Terry,OH
Terry,OH's Avatar
The nozzle bars you pictured are for the 2100 Carb.
Old 08-25-2016, 06:33 PM   #7
Capt Kirk
Capt Kirk's Avatar
Considering the couple issues found with your carb based on the pictures, I'd try another carb as well too. It's a quick and easy check and will answer a lot of questions. You may have more than one issue that you're fighting with. If a loaner carb fixes your idle issue and you're low vacuum then you have your answer. If a loaner carb fixes your idle issue but still have low vacuum then you've got things whittled down to a manageable level.
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Capt Kirk is offline   Reply With Quote
Old 09-03-2016, 07:28 PM   #8
david.skinner
Update time. The main source of the problem is a sticky and leaking throttle shaft. Complications were a small leak in the inlet manifold. No vacuum to the distributor, and numerous small faults in the carb itself. I'm just organising for a replacement base now. I found it by accidentally jamming the throttle butterflies completely closed and all of a sudden the vacuum jumped up to 20" and the idle mixture adjustments started working properly. In the meantime I also have a new inlet manifold gasket, nicely painted inlet manifold, replacement V belt of the correct length this time, and a nice new shiny vacuum feed line to the dizzy. Thanks to everyone for your guidance. Not a hope I would have got there without the support from the people on the forum. Pictures of the offending article attached.
PS: Anyone know the thread size on the small vacuum port on the manifold riser?
Old 09-03-2016, 08:05 PM   #9
flatheadmurre
flatheadmurre's Avatar
Get a new oversize shaft ream the base and you are good to go.
Most used ones are worn and finding a good one will take more time then getting the old one back in shape.
Old 09-04-2016, 06:23 PM   #10
david.skinner
Temporary fixes in place and dead steady 19.5" on 600rpm - tried to upload a video of it idling I was so happy but don't think we can post video's. Thank you again to everyone. Just some spare parts to find and fit now and all fixed.
Regards
David
Old 09-15-2016, 04:45 PM   #11
david.skinner
Just a final update and a public thank you to CharlieNY on this forum. Charlie has been helping me with this problem and with some parts and thanks to his guidance and generosity this quite complex problem has been solved. Thank you CharlieNY.
D.
