Old 05-24-2016, 07:42 PM   #1
Dick Steinkamp
Dick Steinkamp's Avatar
Default Re: How do you stop vapor lock?
For you that believe that ethanol is a cause of vapor lock, the opposite is actually true. Ethanol boils at 173F. Gasoline starts boiling at 90-100F. In addition, gasoline is substantially easier to vaporize than ethanol.
http://www.txideafarm.com/ethanol_fu...s_and_data.pdf
Ethanol certainly has some down sides, but contributing to vapor lock is not one of them. In fact, the more ethanol in the gasoline, the LESS chance you have of experiencing vapor lock.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 05-24-2016, 07:55 PM   #2
tbirdtbird
the problem is the mixture has various boiling points...blended fuels no longer exhibit the properties of the individual components...
https://tsocorpsite.files.wordpress....ol-and-gas.pdf
which states that the boiling point can range from 85 – 392°F, depending on many factors
'31 180A
tbirdtbird is offline   Reply With Quote
Old 05-24-2016, 08:31 PM   #3
txkhog
Could you add a pressure bypass line up next to the carb inlet and return to the gas tank. The bypass will keep gas circulating in the lines any vapor will be vented out the gas cap. This is what is done on some modern cars.
GDG
txkhog is offline   Reply With Quote
Old 05-24-2016, 10:25 PM   #4
tbirdtbird
That is a very workable solution if you can arrange it. I have seen that done on several restorations, but none were As. One was an Amphicar. The problem for an A is just where would the return line go, and an electric fuel pump would have to be added for pressurization.
Another thing that we Texans do is to put the Zeniths on the shelf and roll out the Tillies. Tillies don't vapor lock even with crapahol gas. Die cast gives up the heat, cast iron soaks it up
'31 180A
Old 05-25-2016, 07:55 AM   #5
updraught
updraught's Avatar
From the same web site as the book, in the tech tip section:
"Hot drivability/hot restart problems are primarily warm weather problems. Today, the EPA regulates the vapor pressure of all gasoline during the summer months (June 1 to September 15 at retail) resulting in maximum permitted vapor pressures ranging from lower than 7.2 psi to 10.0 psi depending on the type of gasoline and area in which it is sold. Therefore hot drivability and hot restart problems such as vapor lock and fuel foaming have been largely eliminated (except for antique vehicles) for modern cars and trucks. All of us who drive antique vehicles with five pounds of fuel pump pressure still experience drivability issues. The alcohol in the fuel also dries out gaskets in the carburetor and fuel system.
The alcohol can also cause damage to rubber fuel lines and the rubber diaphragms in mechanical fuel pumps. We buy less than one percent of the gasoline sold in the United States so we are pretty far down on the food chain."
http://fifthaveinternetgarage.com/pd...rnGasoline.pdf
updraught is offline   Reply With Quote
Old 05-25-2016, 09:18 AM   #6
John Stone
John Stone's Avatar
IMO the gas line is really not the problem. It is the carburetor getting too hot and causing vaporization. MMO usually works to a point. I know I never had the problem until the alcohol gas came on the market.
John Stone is offline   Reply With Quote
Old 05-25-2016, 09:27 AM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Exactly right.
My Stude and other cars I owned never had problems until the late 80's. I have some white wire wrap that I put on my Model A when I had to use the crap gas, and the white wrap did help, but wasn't a total cure. Gas without the corn crap was the total cure for the Model A. The carb on the Stude gets hot because it's right over the exhaust manifold and preheater, and the fuel today will boil in the bowl, so the intake is flooded when I try to restart the engine after a short stop at the store.
Some nice asbestos wrap on the exhaust would probably help, but the EPA, in their ignorance, has banned it. I'll have to see if there is some other kind of wrap that might help.
Old 05-25-2016, 10:02 AM   #8
Cool Hand Lurker
Cool Hand Lurker's Avatar
I think aluminum clothes pins would help.
Cool Hand Lurker is offline   Reply With Quote
Old 05-25-2016, 03:10 PM   #9
1931 flamingo
1931 flamingo's Avatar
part # and source ??
Paul in CT
Old 05-25-2016, 03:18 PM   #10
emf
emf's Avatar
How about these:
Aluminum Clothespins
emf is offline   Reply With Quote
Old 05-25-2016, 05:00 PM   #11
Safewiz
Safewiz's Avatar
Just a thought, but I had a bad vapor lock problem that stemmed from the heat from the manifold transferring to the carb. Caused the fuel to boil in the carb. I put a heat sink plate between the manifold and carb. Solved my problem. And I had a electric fuel pump as well. It was half inch thick and made out of wood.
Safewiz is offline   Reply With Quote
