Old 08-12-2015, 10:02 PM   #1
1955cj5
1955cj5's Avatar
Default Re: Pulling The Engine
OK thanks...it ought to go just fine.....
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 08-13-2015, 02:57 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
I find a couple guide studs to be very helpful, but as Vince said, about 3" long should work fine.
There should be no fear of breaking an ear. Just use common sense when you tighten it, and stop if it doesn't feel right.
Old 08-13-2015, 10:52 AM   #3
CarlG
CarlG's Avatar
The guide studs, a frame spreader, and a friend to help are all good to have on hand.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 08-13-2015, 11:11 AM   #4
1955cj5
1955cj5's Avatar
I did get my neighbor to help..I'm not sure if I could have done it alone...
But its done.
I did not use the alignment studs, I did not need the spreader. With me rocking the engine and my neighbor pushing we were able to squeeze it in between the mounts..a little grease helped too...
Thanks for all the suggestions...
I'll let you know how it runs...
Old 08-13-2015, 11:13 AM   #5
Mitch//pa
glad to see the fender covers
hope all turns out well for u
Old 08-13-2015, 12:06 PM   #6
jeep44
Looks good!
jeep44 is offline   Reply With Quote
Old 08-13-2015, 07:11 PM   #7
1955cj5
1955cj5's Avatar
I runs and it runs good! Much much quieter than before....more later, I'm exhausted...
Old 08-14-2015, 07:13 AM   #8
chap52
chap52's Avatar
Thanks for the play by play report. Sometimes these adventures are like going to the dentist. Thinking about it before you go is sometimes more painful that the appointment. And the bill in both cases is always a shocker...
chap52 is offline   Reply With Quote
Old 08-17-2015, 09:32 PM   #9
1955cj5
1955cj5's Avatar
For sure the anticipation was worse than actually getting in there and doing it. Once I drained the fluids there was no going back.
The effort was well worth it. I can't imagine trying to set up the main and rod bearings from under the car, and getting the pan back on with a good, so far leak-free seal would have been tough.
I set out to change the clutch, pressure plate, throw-out, pilot and transmission bearings and the timing gear, along with adjusting the main and rod bearing clearances. also the gasket between the block and the flywheel housing needed to be installed, as there was none there.
I did all those plus the crank timing gear, new clutch actuating rod and bushings, oil pump shaft and gears, oil pump/distributor drive gear, and the distributor shafts.
Only 50 miles so far but I am pleased with the result. It runs smooth at 40 to 45 where it used to get a good vibration, and the new clutch and pressure plate really improve shifting. And it only leaves two or three drops of oil when parked as opposed the the 5" or 6" puddle it left before..that gasket made a huge difference.
The clutch pedal force is about 50% greater than before, and that is with all the linkage clean and lubed. That old pressure plate was just worn out, along with the clutch disc.
I think that's it for now.
Thanks to all for the input...
I'll let you know when I have 500 miles on it..
Randy
Old 08-17-2015, 09:46 PM   #10
Fullraceflathead
Fullraceflathead's Avatar
Great feeling to accomplish all that work yourself!
That's what makes the Ford Model A so Special!
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
