Old 08-31-2015, 01:01 AM   #41
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Default Re: New guy with 1931 Model A Sport Coupe
Originally Posted by Brentwood Bob View Post
Wow! Good to hear your father in law has seen the car coming along.
That is priceless.
Bob
I agree, priceless!
Old 08-31-2015, 05:35 AM   #42
RonC
RonC's Avatar
I would take the head off and find out why the head studs are so high. I would be concerned they are not screwed in. You might have to replace them with the correct studs. Get rid of the washers.
RonC is offline   Reply With Quote
Old 08-31-2015, 11:12 AM   #43
40 Deluxe
RonC, No need to pull the head, just remove one stud to check the length, see if it will turn in further, etc. If it won't come out with your fingers, just double nut it. And, what's wrong with the washers (as long as they are grade 8)?
Old 08-31-2015, 11:57 AM   #44
160B
160B's Avatar
Originally Posted by RonC View Post
....................... Get rid of the washers.
The washers may be there because the thread form on the stud is not long enough for the nut to contact the head.
Before you torque the head remove one nut and see how much thread form you have. You do not want to torque the head if the nut bottoms out on the end of the thread form. If you have adequate thread form so the nuts do not bottom out then torque the head. If there is not adequate thread form than the studs are not threaded far enough into the block and they will have to be threaded in further.
You also need to torque the head nuts in the correct sequence to the correct torque 65# as I recall.
First torque the head and then run the engine without any water in the block until the head is warm to the touch and let the engine cool to ambient temperature and re-torque the nuts in the correct sequence, do this a total of three times or until the nuts do not take any more torque.
Others please chime in on this as you see the need.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 08-31-2015, 01:13 PM   #45
Willie Krash
Willie Krash's Avatar
Yes welcome. You may be in for the most frustrating fun you have ever had....but well sort itself out. Keeps me out of trouble.
Mike Stitt
"A business that make nothing but money is a poor business."
-Henry Ford
Willie Krash is offline   Reply With Quote
Old 08-31-2015, 02:22 PM   #46
Jeff/Illinois
Jeff/Illinois's Avatar
Nice car! And, thanks for the pics and updates!
Having your wife and daughter on board with this project is worth a LOT more than money!! Good to hear they are behind you.
Jeff/Illinois is offline   Reply With Quote
