12-23-2014, 01:50 PM | #41 | |
Re: Why Fiber Timing Gears
No disrespect to any question asked, but it has been answered multiple times, in this string alone. It's as though some are asking for validation to their point of view, and if I don't agree with it, I can't give it. Simple as that.
12-23-2014, 05:24 PM | #42 | |
these cars are only our big boy toys anyway, and we should never let them affect our health. |
12-23-2014, 05:36 PM | #43 |
we can divide this up. Carl, wanna finish out this thread? I don't mind taking it the next time. Maybe Purdy would be willing to take it after me.
'31 180A |
12-23-2014, 06:26 PM | #44 |
I can't find the bronze gear listing at synders? I found aluminum and fiber...
12-23-2014, 06:38 PM | #45 | |
He's the guy that makes them -- very nice guy to deal with.
12-23-2014, 07:30 PM | #46 |
'31 180A |
12-23-2014, 08:01 PM | #47 |
The Murray Fahnestock book claims that Model "A" did not use timing chains (which most other cars did, I think) because of the costs associated with producing a chain composed of many links, which would eventually need adjustment, versus a simple fiber gear.
It sound like many guys have legitimate problems with fiber though I wonder if this is simply because the quality is not like original. |
12-23-2014, 08:34 PM | #48 |
Eric I think you are onto something.
In that era, engines that did use timing chains frequently used a type of chain known as a Morse silent chain (named after the manufacturer). I have worked on numerous motors that used these chains. They are rugged as can be, never need any adjustment, and are indeed as silent as can be. It is hard for me to understand to this day how they can be so silent, after looking at many of them. They are still available. Some of the old timers on here may remember them. My first exposure to them was on a 1911 Stafford car (the last such car in existence: I worked on car number 245 of 347 ever made). They are an engineering marvel. You will never break one. I just finished working on a '32 GMC 1.5 ton grain truck which has such a chain. We invited as many car buddies over as possible to take a gander; their eyes popped.
'31 180A |
12-24-2014, 08:08 AM | #49 |
I wonder why some modern producer did not make a nylon gear. Should be quiet but maybe it would melt?
12-24-2014, 08:49 AM | #50 |
12-24-2014, 10:55 AM | #51 |
GM's nylon coated cam sprockets wasn't a good idea. It wasn't if they would fall apart, but when. The one on my dad's 1970 Pontiac fell apart when he was 1000 miles from home.
12-24-2014, 01:34 PM | #52 |
12-25-2014, 02:20 AM | #53 |
Guys- I feel a little clarification is in order regarding replacing both gears at the same time. With regard to the noise issue- when a customer calls and wants to know if metal gears make noise, I tell them that properly made gears installed on correct center distances (correct backlash) do not make noise. An issue arises when someone wants to buy just the cam gear- I'm more than willing to sell them the part, but since I have no control over the condition, or the original quality of the mating gear, I can't make the statement that the gear set will run quietly. Would you mix ring and pinion gears in a rear end or replace just the ring gear with a new one and expect good results? Timing gears are no different- You may be fortunate enough to replace only the cam gear with good results, but the fellow who does not have good results is usually the one telling his friends that you should use fiber gears because all metal ones make noise, when the fact is the same meshing problems exist with a fiber gear, and the teeth are slowly disintegrating but you just don't hear it until its too late.
I hope this helps a little. Dan |
12-25-2014, 02:53 AM | #54 |
Thank you Dan. Yes, your explaination, did help clarify the issue.
12-25-2014, 02:05 PM | #55 |
Its more important to replace both gears when a fiber cam gear is used or it will strip teeth quicker. Unmatched metal gears may make a faint noise in worse cases but won't strip teeth. A person is on their own and shouldn't blame the gear maker. For me it will be metal gears as long as I can get them. In most cases with my cars I will take the easy way and replace the cam gear unless the crank gear looks bad or the engine is out. In most cases this is probably what most do.
12-25-2014, 06:51 PM | #56 |
