06-28-2011, 08:13 AM | #41 |
Re: Curious question on alternators
I'm wanting a few more amps out of my "genny" so.... I'm going to run a Model-A era Delco-Remy generator instead of an alterantor. I have an aftermarket accessory bracket from back in the day that will let me do this. Just my .02 cents for this very interesting discussion.
Bob-A |
06-28-2011, 08:14 AM | #42 | |
UhOh...... |
06-28-2011, 08:54 AM | #43 |
As a newbie, I can confidently say that novices and non-owners notice the modern anachronism. It's a shock (for a non-owner) to see an alternator on a Model A.
Ray White |
06-28-2011, 09:14 AM | #44 | |
I will sell the whole thing cheap (plus postage) if anyone wants to go this route, although I can't understand why. Steve |
06-28-2011, 11:35 AM | #45 | |
06-28-2011, 10:08 PM | #46 |
Bill |
06-29-2011, 01:44 AM | #47 | |
Yes, the EVR will automatically adjust the generator output as needed, whether it is to charge a low battery or send more power to run the headlights, when they are turned on. The voltage regulator senses the voltage thousands of times a second and as soon as it falls below the norm the EVR will send more power to the field coils. This makes the magnetic field stronger, which makes the armature generate more electricity. As soon as the voltage is back to norm, the EVR cuts back the power to the field windings. As you can see in this picture the EVR I make fits inside the generator and takes the place of the adjustable brush and it's holder. It's out of sight, so the generator looks totally stock, but is fully regulated, like modern cars. Actually I should say regulated like most cars have been since the late 30's, as that's when most cars were regulated by electro-mechanical voltage regulators. |
06-29-2011, 07:15 AM | #48 |
06-29-2011, 07:40 AM | #49 | |
On newer cars this supply is fed through a lamp which will light if the alternator cannot sustain its own field anymore usually labeled ALT or BATT. It must also be on a keyed switch for obvious reasons. |
