#41 |
Absolutely, you are lucky to be here to tell the story. Glad you're ok. There are too many similar stories. Last year I sold a set of tubeless replacement wheels to a guy who told me he'd just bought his truck, and as he was loading it on the trailer to haul it home it blew an inner dual widow maker. His first act was to find safer wheels. Stu
Stu McMillan Marmon-Herringtons |
#42 |
Thinking about the split rim wheel, I played a cruel trick on an older fellow worker. He was always playing little tricks on me that he thought was funny. One day he was putting air in a truck tire under the hoist and I was cleaning the tools on the work bench. He was watching the wheel very closely as he inflated it. I took a ball peen hammer and slammed the other end of the hoist. He threw the air hose straight in the air and yelled out loud. If looks could kill...I never apologized and he never played any tricks on me again.
Son, you will never blow an engine up in high gear. |
#43 | |
![]() Quote:
Here is a single 17.5 listed on ebay: http://www.ebay.com/itm/111016808669 I suppose could source them one at a time since I have not heard back from the Fla fella yet.. |
#44 |
That one is for a Chevy. Hub cap clips won't work for you, and center hole too small to clear your rear hub. Keep looking. Stu
#45 |
Brien - I've emailed a friend who I've known to have his eyes open for these wheels over the years. He's replied that he doesn't have any right now, but will check his yard sources to see what he can find. I asked him to check on all three options - the stock 16" F-2/F-250 wheels, the 17.5s, and the 19.5s. What we'll need to know, however, before thinking in terms of the 16s is whether you have the early 1951 14" rear drums, or late 1951 12" rear drums. Please check that if you would so that when he gets back to me, if that's what he's found, I'll know whether to refer you to him. Thanks. Stu
#46 | |
Sure Stu.. I will know tomorrow. You have been a great help to me...Thanks again..Brien |
#47 |
BTW, those are inside diameter measurements. The outside of the drum will be bigger. Stu
#48 |
Try this wrecking yard. "TAV8CarsNParts" <[email protected]>
I got a spare set of 17" 5 lug wheels from them about 8 years ago. They had a good quantity of large truck parts at that time. |
#49 | |
![]() Quote:
#50 |
#51 |
Well, that eliminates the 16" F-2/F-250 wheels. They won't clear your rear drums. But you still have the 17.5s and 19.5s to focus on. Assuming you still haven't heard from the guy with the 19.5s, which says he's not serious, there are the below two 17.5s that look correct for you.
http://www.ebay.com/itm/151002291451...84.m1423.l2649 The only hesitation I'd have is that these wheels still have their tires mounted. A couple years ago I had a pair of 17.5s that held air and that I used to move parts trucks around in the barn. A guy, like yourself, needed them so I had the tires removed intending to pass them on to him. What I found was that both had severe inner rust that wasn't detectable with the tires mounted. I ended up junking both. This is one of the unforeseen issues that can be encountered when dealing with old stuff like this. Stu Edit - my buddy just got back to me and told me his yard sources have turned up nothing. Stu
Stu McMillan Marmon-Herringtons Last edited by truckdog62563; 02-27-2013 at 08:42 PM. |
#52 | |
![]() Quote:
#53 |
As a another source, I texted another buddy today asking that he keep an eye open for these next time he goes out to his favorite yard. It's a big yard that holds promise, but might not be a right away solution. Stu
#54 |
Bump. My buddy texted me back that he's found a couple, but has to see if he can get the guy to turn loose of them. They aren't in the yard, are on a cutoff pickup box trailer. These with the eBay pair and your spare would set you up. Stay tuned. Stu
#55 |
Brien - you must be living right! Just moments ago I got a private message over on the FTE board from another of the guys that keeps his eyes open for these wheels. He's found today, and bought, a full set of 17.5" Budd #73240 wheels like you need, in good shape, with the tires already pulled. I've suggested that he drop in here to comment. Hopefully you two can work out a deal. Stu
#56 | |
![]() Quote:
I would like that even though I bought those two rusty rims for only $50. for both. This is a third one for sale: http://www.ebay.com/itm/111016810061...witem=&vxp=mtr I am still open to buying 4 good ones... |
#57 |
Yes I am tuned..Thanks for all of your efforts Stu You are a great guy to help me in the way you have done here. Thanks again.
#58 |
Here's pictures of the wheels my friend Doug (user name "opkomdalen" on FTE) found yesterday. I suggested he drop by here and look you up, but suspect he's not a member. If need be I can get his email or phone for you. I also texted my friend Mark and told him to sit on the trailer wheels for now.
BTW, there are two wheels that match the description, one is this #73240 and the other is #70720. I've had both and they look identical. The #73240 is a slightly more recent wheel. If you look at the back/concave side of you own 17.5" you'll find one of those numbers along the raised area that is the drop center. Stu ![]() ![]() ![]()
#59 |
Thank you Stu I would be more than happy to talk to Doug via email or phone. My toll free is 800-774-7971 9 am - 9pm Eastern Time...
#60 |
Brien - I'm gonna do you a private message to go a little deeper into this. No need to put that here. Stu
