#41 |
I'm looking forward to those doughnuts, DD!
#42 |
One thing I do when having this problem is to tap the stripped hole out to 12 mm.then make a stepped stud,12mm in the block, and above 7/16,this may not work if the hole is now bigger than the 12mm root diameter.
Lawrie |
#43 | |
![]() Quote:
It's kinda funny to see metric references on Flathead repair! Old Henry wouldn't be having it...would he? Were any of the foreign built stuff metric? This has been a VERY interesting thread to follow...I learned a lot. You guys are a wealth of knowledge... ![]() |
#44 |
#45 |
Yes Lawrie, a helicoil had pulled out and the problem hole was already larger than even a 1/2" bolt hole.
#46 |
Just thought of something else with your bigger stripped helicoil hole. You probably coulda tapped it for 3/8-18FPT and used a turned down 3/8-18MPT stud the same way. Maybe???? Jack E/NJ Last edited by Jack E/NJ; 11-03-2016 at 06:00 PM. |
#47 |
Well we've solved one thing here, nobody is going to uz heli coils to fix head stud/bolt holes anymore.
#48 | |
![]() Quote:
![]() There 1000's of mil spec heli coils used on aircraft engines all the time.Just remember that when you fly next.It was good to see that a reasonably priced repair was arrived at to keep another flatty running and serving its owner well.Another happy ending. ![]() R |
#49 | |
![]() Quote:
The pilot bearing in the middle of the flywheel is metric, believe it or not. Martin. |
#50 | |
![]() Quote:
I had no idea the pilot bearing or anything else was metric on them. |
#51 |
#52 |
From what I saw---read the inside ---bottom of the hole has less thickness on one side like there is metal loss inside---deck less thick on one side of the hole, plus there is a crack from that hole---normal thresds push out because of their tapered design, I would think the repair should be using something that pulls the crack together to get maximum holding power without putting pressure on the crack---so look at "full torque inserts, they have a hooked thread that doesn't put outward pressure as tightened--
http://www.lns-sea.com/products-ft.htm#briefing If the hole is large, off center they have blank inserts that will allow the original thread placement in the location required |
#53 |
Kurt is correct about the thin deck on one side of the hole. I asked the machine shop to remove a broken head bolt and it came back with the helicoil. I couldn't tell that the bottom coils weren't attached in the deck. The "full torque inserts" might have been a better fix IF I had known about it at the time. Where were you when I needed you, Kurt?
#54 |
Spark plug threads 14mm
#55 |
#56 |
I think the 203 bearing is used in the front of ford generators. 17MM X 40MM
Also has anyone else found Mazda light bulbs in their original Fords? Bruce
Works good Lasts long time |
#57 |
Most bearings have been in metric sizes for eons. Nothing new there.
R |
#58 |
Still Metric, but I believe the Mazda bulbs were French. The Mazda company who made bulbs made some really good electrical pieces such as vacuum tubes and such.
#59 |
14 mm on the early steering boxes .If you cannot get a solid fix I think you will be relying on the studs each side of it to give most of the tension ,use the best gasket sealer you can find .to save bridge a block and if your not worried about looks you a metal plate
#60 |
There are a lot of places that the metric system crosses over in diameters. With threads, there is a difference. Very few if any metric threads cross over with unified threads mostly due to the different thread pitches. Aircraft spark plugs are all still unified type threads but automotive applications have been metric for a very long time.
