Old 03-01-2013, 04:45 PM   #1
Dune Country
Default bad day for the A
Just venting here,
body work all done and cab and bed in primer. Had the cab on low saw horses tipped forward on some blocks and a milk crate so I could paint the bottom, which I did, looked like a good time to take the doors off, pushed on the screwdriver and the milk crate collapsed and the whole thing rolled forward onto the top,bent the sun visor in two places where it hit the saw horses and the back of the cab hit my grinder stand and dented it. Had to weld a 3/16 strap up under the visor to keep it straight and redid bodywork and primer on the back.
THEN
started to wet sand the orange peel on the already painted fenders,first time painting urethane, have always used acrylic enamel, anyway ,I did put (what I thought) 3 good coats on the fenders,waited 72 hours and started with 1000 and then 2000, sanded right through in a couple of spots.
turned off the lights and closed the door,sat down and had a beer.
plan to finish sanding and recoat with a wet coat.
ever had "one of those days?"
thanks for letting me vent
Greg
Dune Country is offline   Reply With Quote
