Old 01-16-2014, 01:49 PM   #21
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Poor Generator Practice
Here's another example of extreme commutator cutting. Notice the small diameter of the commutator and the large gap between the brush holder and commutator. Even though the brush may look full length the spring is almost hitting it's stop, so the brushes will have a short service life. The brush holder also appears to be off center, which makes the problem worse. This generator is on ebay right now.
A properly restored or repaired generator doesn't mean the commutator has to be cut. They only need to be cut if they are rough or have a burned segment, or have runout.
Old 01-16-2014, 03:25 PM   #22
montanafordman
montanafordman's Avatar
This isn't the only seller I have seen who goes on about their decades of experience rebuilding generators and has questionable parts and/or shoddy work as a result. Unfortunately I've been burned in a similar manner. Someone can find a junk generator at a swap meet and do his homework in the process and with an eye for detail do a far better job than many so called "professionals." Just because someone has years of doing something doesn't mean they do it well or care - that's up to the individual. I've been fooled once.
Aaron in T̶a̶c̶o̶m̶a̶ Meridian, Idaho
(although still a Montana hillbilly at heart )
1931 Coupe
1931 slant window sedan
montanafordman is offline   Reply With Quote
Old 01-16-2014, 03:40 PM   #23
quickchange
quickchange's Avatar
Tom , Well done , great pictures . Where do you get the 5 brush brushes from ??Don,t see them listed in catalogs ? Have about 10 power houses laying here if anyone wants , freight could be a little pricey ??
quickchange is offline   Reply With Quote
Old 01-16-2014, 03:58 PM   #24
Tom Wesenberg
I haven't needed any for some time, but do need to find a good source or make my own by cutting down a larger brush and reuse the wire and terminal from the worn brush. Drill a small hole and use a small brass screw to hold the wire in place. About 15 years ago I had a powerhouse where someone had done that for a brush set.
Old 01-16-2014, 04:19 PM   #25
tbirdtbird
that commutator has been waay undercut....
'31 180A
tbirdtbird is offline   Reply With Quote
Old 01-16-2014, 06:27 PM   #26
Jon
Jon's Avatar
This isn't the only seller I have seen who goes on about their decades of experience rebuilding generators and has questionable parts and/or shoddy work as a result. Unfortunately I've been burned in a similar manner. Someone can find a junk generator at a swap meet and do his homework in the process and with an eye for detail do a far better job than many so called "professionals." Just because someone has years of doing something doesn't mean they do it well or care - that's up to the individual. I've been fooled once. [/QUOTE]
I was taught that: "Practice doesn't make perfect, only perfect practice makes perfect."
John - Kalamazoo, MI
Jon is offline   Reply With Quote
Old 01-16-2014, 09:54 PM   #27
QGolden
QGolden's Avatar
Thank you Tom, I appreciate the time you take to share.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain.
It is the very things that we think we know, that keep us from learning what we should know.- Unknown
QGolden is offline   Reply With Quote
Old 01-16-2014, 10:22 PM   #28
pat in Santa Cruz
pat in Santa Cruz's Avatar
what a shame a good generator is virtually ruined by an amateur BS'er, who also takes the innocent hobbyist's money. Thank you Tom for the informative post, and for explaining to us what to look for so we don't get burned by these guys.
pat in Santa Cruz is offline   Reply With Quote
Old 01-18-2014, 08:13 AM   #29
Mafman
Mafman's Avatar
Great posts, Tom. Thanks for the great generator lessons!
James Johnson
1928 Special Coupe,
1930 Tudor Sedan, &
1939 Deluxe Fordor
Mafman is offline   Reply With Quote
