#21 | |
![]() Quote:
#22 |
Here is a NOS for E28
A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
#23 | |
![]() Quote:
Charlie Stephens |
#24 |
#25 |
Interesting as Mick Isbell says YES! to E28 (Jan to be exact)
#26 |
http://www.abarnyard.com/ |
#27 |
Thanks Marco,
I see what your saying. Any comment on the lettering, font,...which ones are correct? |
#28 |
I think the last style "T" ammeters had Ford script face plates and the bezels are flat
#29 |
I went out to the garage today and after cleaning up some of my mess from the day before I looked at my miscellaneous electrical box and found another ammeter.
Here is a photo of two of them. In this photo I can see the whitish lettering on the one on the left and the one on the right has more of a silver look to the lettering. With the two of them in the same photo and same lighting the difference is more apparent. Great feedback from everybody, thanks. This is what Fordbarn is about!!! |
#30 | |
![]() Quote:
Yes, this has been a good discussion on original Amp Meters. Thanks guys
Jamie Crosson 1929 Tudor Looking for an Original 888 Key |
#31 |
Interesting thing about this NOS ammeter is the division markers between the numbers. It has only 3 lines between the numbers not 4 like most ammeters. I have no explanation although the box is post era.
#32 |
So, after reading all these post about original ammeters, I came home today, disassembled mine, cleaned everything and reassembled. Other than the plating on the bezel, I do not think any other work will be required. I'm always amazed at how these 83 year old parts clean up with relatively no effort.
Again thanks for all the informative post.
#33 | |
![]() Quote:
could you post a photo of the back of the ammeter? thanks for the post 160B |
#34 | |
![]() Quote:
#35 |
Tom, I have started polishing with Flitz metal polish. It is doing a decent job. I'll post some pictures after a little more elbow grease. Probably finish it up tomorrow afternoon.
#36 |
Are we saying that all 4 years had the exact same amp. Including E28. Curious on this please.
#37 |
Mark,
Take a flashlight battery, such as a D cell or AA, etc. and a piece of wire and connect the + to the passenger side of the meter and connect the - to the driver's side of the meter. The needle will move to the RIGHT on a Model A ammeter. Just do this briefly because this is a dead short on the battery. |
#38 |
#39 |
We spelled it out in the revisions. Since the subtle differences in the needle and face plate are likely supplier variations and there are no records that specify supplier specifics or timelines for those suppliers, it would be more than a bit presumptuous to limit the use of either variation. However the actual "Model A" ammeter was documented long before actual production of cars ever began so the use of a Model T version would be a stretch to say the least.
#40 |
I'm looking at an ammeter I just got off eBay, and it has the dimple in the back like yours. Was this the only way to tell it's an E28, or was this simply a manufacturer's dimple? Does such a dimple indicate that it is in fact an original?
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
