Old 08-18-2012, 01:34 PM   #1
mrmoose
mrmoose's Avatar
Default 1941 4 cylinder pickup
A lot of folks here and over at the HAMB have been looking for information on the 4 cylinder available in Fords for a short time in the 40s. I've owned for the last 6+ years a 1941 Ford pickup with that 4 cylinder engine. While I'm no expert, mine is largely original and I've learned a little bit about them and was asked to share.
Here is Clem before he arrived in sunny Florida from Wisconsin...previously owned by 2 working farmers and one "gentleman" farmer...
1941Jan06 by mrmoose1, on Flickr
Polished up a bit by the new owner...an ungentlemanly farmer wannabe...
100_0354 by mrmoose1, on Flickr
And here's a shot of the little 4 banger. These were exactly the same as the 9N Ford tractor motor with the exception of the air cleaner, fuel pump (gravity feed on the tractor, mechanical on the pickup) and governor (none on the pickup) and were mated to the Ford 4 speed non-synchro transmission. I've seen the HP rated from anywhere from 23 to 40 HP...they are slow, very slow, and as a result did not sell well...it is thought only a few hundred were produced, but I have never been able to verify production numbers. Being rare doesn't make one especially desirable, as again, they are slow. That does not stop me from driving Clem every weekend, and occasionally on weekdays, in Florida traffic. All I do is force everyone around me to have a little more patience...and it has worked thus far. I have had him up to 60, but it took some time getting there. 4.55 rear end. Cruises comfortably at 50 though.
040708 025 by mrmoose1, on Flickr
I have rebuilt the front end and replaced the spring, replaced brakes, and the little truck really goes down the road nice. Clutch is nearly gone though, and Clem shifts very hard and sloppy, so will need to pull tranny in the near future.
040708 023 by mrmoose1, on Flickr
After replacing a blown head gasket and a little cleanup, the little motor looks a little better..(note original wiring harness...risky)
to 120609 007 by mrmoose1, on Flickr
You'll see Clem change little by little over time..
1941 Ford pickup "Clem" by mrmoose1, on Flickr
Had the running boards coated with a bed coating called LinerZ...was applied very hot....tough stuff, and I don't slip off the boards when wet now...
1941 Ford pickup runningboard by mrmoose1, on Flickr
Clem does not shirk from work....
to 062809 016 by mrmoose1, on Flickr
1941 Ford pickup by mrmoose1, on Flickr
Family and friends go for rides regularly (note unsecured lawn chairs in the back end-living large and dangerous)
truck ridz by mrmoose1, on Flickr
A year and a half ago....time to ditch the wiring harness (fire hazards don't get much more obvious than this)
wiring harness-in process by mrmoose1, on Flickr
Headlight harness before...
headlight wiring-before by mrmoose1, on Flickr
Headlight harness after...if you wonder about the shiney stuff in the bucket, when I repair the old iron I generally grind and paint, or scuff and coat with Gibbs brand as I did here...seems to slow or stop rust. I'm not intent on restoring Clem, only keeping him sort of original.
headlight wiring-after by mrmoose1, on Flickr
Uh oh, fat boy down! They'll probably need a crane to git me outta there! Stuck under there working on the harness. Note the 60mph speedo. Of the few of these you'll see most have replaced with the 100mph speedo which is correct for the 6 cylinder and the 85HP V-8 but not for the 9N.
031211 030 by mrmoose1, on Flickr
031211 028 by mrmoose1, on Flickr
052811-2 007 by mrmoose1, on Flickr
Neat item...an Optima battery inside a Ford script case....I got tired of replacing the NAPA 6V batteries (generally old when you buy them) and not being able to count on them, so spent the long $$ on this. Very pleased so far.
081812 002 by mrmoose1, on Flickr
So there you have some of the basics. I have thought of replacing the little 4 with a proper flathead, and have the correct front crossmember and a rebuidable radiator in the shed, but generally have decided to keep the little 4 in there. The decision is aided by a lack of funding, which I guess isn't always a bad thing. I hope I've helped a little with what you may not have known....if questions be patient as I do not get hereas often as I'd like sometimes.
mrmoose
mrmoose is offline   Reply With Quote
