Old 11-03-2011, 11:47 AM   #21
Ron Lachniet
Ron Lachniet's Avatar
Default Re: Can cast parts be welded?
I have had good luck welding cast iron with my mig welder. I just work slow and not build up too much heat.
Ron Lachniet is offline   Reply With Quote
Old 11-03-2011, 11:50 AM   #22
Modelakid31
Send a message via AIM to Modelakid31
UPDATE! ...
here is the part after i glass beaded it for 30 mins. just got to prep-all it before i weld. To me it looks like Cast STEEL???
Its pretty minty minus the cut marks and the one hole. :/
Modelakid31 is offline   Reply With Quote
Old 11-03-2011, 12:00 PM   #23
John Duden
John Duden's Avatar
Default Re: Can cast parts be welded? UPDATE (blasted part)
I have welded cast that has snapped (axle on a cultivator) i put it in the grill for an hour pulled it out and welded it with the wire feed, ground deep grooves into the welds and shaft (1/4-1/2 inch deep) welded it shut on high, so it burned it in to the axle, and then stuck it back in the grill to let it cool off slowly,
I am 14 so you can probable do it!
John Duden is offline   Reply With Quote
Old 11-03-2011, 01:29 PM   #24
mystic122468
mystic122468's Avatar
I just had to fix my water pump housing, I used this to Braze it and it worked like a champ!
http://www.lowes.com/pd_98894-717-28...ing&facetInfo=
mystic122468 is offline   Reply With Quote
