#21 | |
![]() Quote:
Stick with the regular bushings, the needle bearing king pin sets are not needed for any application. And as others have said get the bushing fitted to a hand press fit on a Sunnen hone.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery. |
#22 |
Thats what I said ! Have you actually used the needle bearing sets ? Its only upside is that a person with no capability of honing the regular bushings can get his car on the road .
#23 | |
![]() Quote:
#24 | |
![]() Quote:
i know the spindles that came with the car have the bushings already in the spindles and they are reamed to fit the kingpins. all i need are steering arms...i think. and it looks like i may need a "Y" shaped arm of some sort, in addition to the two steering arms, that fits on one of the steering arms. something like these maybe: https://www.speedwaymotors.com/Ford-...gnid=199249975 the consigner said the car was lowered a little, but i can't tell. it's possible i guess, but i don't think it's got a dropped front axle. as it was most likely shown in a car show class focusing on originality. but what do i know? i'm not a car show attendee nor do i hang with car enthusiasts. this is my first american made vintage car. my focus is on multi-day solo trips with a bit of camping...the car is in excellent cosmetic condition, it just needs a bit of mechanical work to make a reliable long distance tourer...i hope. ![]() |
#25 |
FWIW, I rebuilt the front spindles on my very similar Model A with my vise for pressing in the bushings and a borrowed adjustable piloted reamer. It isn't magic.
#26 | |
#27 |
Do you know which bolt on arms you would need? Do you know how to determine which? Every manufacturer makes them slightly different. I doubt any make them intended for use on a stock axle. Maybe you get lucky and the first set fit fine. Or maybe you get to buy another set.
Or maybe you eliminate the headache and a local guy can hone some new bushings in your original spindles. |
#28 |
Can you get the spindles off the axle to begin with? It really doesn't matter which pair spindles you use but in the end the originals will be cheaper in my opinion better for you application. You already have the king pin set. The speedway ones will fit the ford spindles. Any machine shop the does engine work can and most likely will, and has done plenty of bushings. Sell the speedway spindles for $150.
#29 |
Well , I wouldn’t have used the original spindles if the new speedway stuff was better . If you still have the original, use them . Theres so much more possible complication coming your way if you decide to use the aftermarket spindles. For instance , camber angle , ackerman , having the correct bolt on arms , that will probably need heating and bending .
There is a reason my set , like yours is sitting in a box with the disc brake kit . I have used speedway spindles on a light T bucket build . The problems that arose I’ve already brought up . |
#30 | |
![]() Quote:
although i've never done it, i don't know why i wouldn't be able to get them off the axle, the undercarriage is clean and neat. is there some difficulty i should expect? |
#31 |
Support the front axle , use good jack stands . Remove wheel and drums . Remove tie rods ( look up on line ) remove brake flex line , remove king pin retainer bolt . Take a few pictures but not too many parts to reassemble. King pin should slide out , may need a little nudge with a hammer using a BRASS punch . The bearing should pull out and the spindle will drop . Be careful, The backing plates should be removed before removing the king pin retainer bolt. I forgot to get that in sequence. Many old shop manuals on ebay that will guide you better than my post can , but you can do it . Pictures and questions will surely help .
#32 | |
![]() Quote:
#33 |
Where on the Central Coast are you located? I am in Atascadero and can press in new bushings and hone the new king pins to fit using a Sunnen pin hone. I've probably done over 100 pairs of early Ford spindles, so something I can knock out pretty quickly.
I agree with everyone else. Re-use the original spindles! |
#34 |
Go Neal . Very nice .
#35 |
#36 | |
![]() Quote:
anyway...i think i have the answer to my question of whether or not i would need to purchase steering arms, at least, with the spindles i found in my trunk (see Post #1). so that's settled. i may or may not have to replace the spindles in the car, but as of yet not verified that i need them. that has yet to be determined. there's a gentleman, now retired, that i've been in contact with up in Santa Rosa (Vern Tardel) that has offered his services WRT to the engine and he may or may not be of service if and when i need suspension work. |
#37 | |
![]() Quote:
Something like this, although I can't tell you if the this drop will be appropriate or not. https://www.speedwaymotors.com/1937-...rop,25525.html
Mike Wanted: - '32-34 Open Cab Pickup (RPU) parts and documents/articles/info - ARDUN parts |
#38 |
To eliminate all the guess work my suggestion is to remove your original spindles and inspect them. Obtain a new kingpin set and have your original spindles refitted .Then sell that set that came with your car.
#39 |
With all of the jaw-jacking you have done since the start of your questions you could have had the work done by now.
#40 |
Mr Tardel has published a series of small repair manual that I have found immensely useful.
I think there are 11 or 12 in the set. Saved me a lot of hassle. Well worth getting! |
