Old 05-07-2025, 06:42 AM   #21
Rice
Default Re: 1941 Semi Truck
It would feel awkward shifting with my left hand, but am sure I could get good at it, if that was mine.
Rice is offline   Reply With Quote
Old 05-11-2025, 06:04 AM   #22
38 coupe
38 coupe's Avatar
Very interesting truck, thanks for sharing the pictures with us.
Post pictures of the engine and radiator and we can help identify those in case you ever need maintenance items for them. Pictures of the intake surface, area above the distributor, and oil pan rails to see if there are core plugs down there.
I was guessing the truck would be geared way down after seeing the 7 ton rating on the trailer. The granny four speed transmission and two speed axle probably got a work out when the truck was in service. Is the shifter looking lever on the left side of the cab the two speed axle shifter? I have a friend with a 39 truck project with a lever shifted two speed, and the lever is next to the left kick panel. Did Ford not make a different axle shifter setup for right hand drive trucks?
Old 05-11-2025, 08:06 AM   #23
51504bat
51504bat's Avatar
Don't know if it's available down under but Gibbs oil is an option to use to preserve the paint. JMO
https://gibbsbrandlubricant.com/
It leaves no sticky dirt attracting residue and can even be painted-over! (Gibbs) Contains No: Silicon's, Waxes, Acids, Corrosives, Teflon, Graphite, Abrasives, Arsenic, Kerosene, Perfumes, Carcinogens or Synthetics.
Old 05-11-2025, 10:55 AM   #24
Cool Kat with Hot Car
Cool Kat with Hot Car's Avatar
what a wonderful beast
Cool Kat with Hot Car is offline   Reply With Quote
Old 06-18-2025, 07:44 PM   #25
Boxhead
Cheers mate I will have a look at it!
Sent from my SM-F956B using Tapatalk
Boxhead is offline   Reply With Quote
Old 06-18-2025, 10:37 PM   #26
Newc
Newc's Avatar
Two rifle clips on dash and maybe the rifle butt fixtures below on floor. CMP fixtures are in the rear of the interior. Fits the Enfield. Newc
