Old 04-05-2025, 06:24 AM   #21
paul2748
paul2748's Avatar
Default Re: 55 Fairlane oil filter choices
Personally, I found that the spin on has little advantage over a canister type. Both are messy and will spill oil when loosening, the spin on maybe a little less so. After two tries with an aftermarket spin on adapter, I went back to the canister. No problems after that. But currently, both of my YBlocks have the spin on added by the engine builders.
The canister type is more eco friendly.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-05-2025, 06:27 AM   #22
paul2748
paul2748's Avatar
Plus shipping = another 6 to 8 dollars most likely.
Originally Posted by KULTULZ View Post
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-05-2025, 08:38 AM   #23
KULTULZ
KULTULZ's Avatar
Wink Re: 55 Fairlane oil filter choices
!!! GOOD MORNING PAUL !!!
I see you are at it early this A.M. ...
Paul, the reason for that exercise was to demonstrate price shopping. Once the product you are searching for is found, you simply PRICE SEARCH. It is no mystery, well, to most anyway.
I really appreciate your using all caps in our last exchange as my batteries were going low and I didn't want to miss any BITS of WISDOM you post here often that you are so well know for ...
Don't Forget -
If it doesn't fit get a BFH. It still won't go, get a BIGGER FKN HAMMER and possibly a HOT WRENCH.
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 04-05-2025, 09:13 AM   #24
KULTULZ
KULTULZ's Avatar
Arrow Re: 55 Fairlane oil filter choices
!!! OH !!!
While I am waiting for my morning MIDOL to cut in and drawing my CALGON BATH ...
The only way to determine if a spin-on out performs a cartridge style filter is with an OIL ANALYSIS, not it "looked so much cleaner after a drain".
Same with motor oils, especially diesel oils in a gasoline engine.There are differing ratings on filter medias.
Only SUPERMAN (maybe also ULTRA-MAN) had spectographic eyeballs.
Old 04-05-2025, 04:17 PM   #25
paul2748
paul2748's Avatar
Shipping always has to be considered when purchasing something that has to be sent to you.
Don't Forget -
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-06-2025, 12:45 AM   #26
KULTULZ
KULTULZ's Avatar
Question Re: 55 Fairlane oil filter choices
I believe it comes under the term 'PRICE SHOPPING', a subject brought up before.
Old 04-06-2025, 07:34 AM   #27
40cpe
40cpe's Avatar
A question came to my mind when thinking about the differences in spin-on and canister filters. Does the canister type have a by-pass? Does either type provide oil flow to a cold engine faster?
40cpe is offline   Reply With Quote
