#21 |
One thing I have learned about corn head grease, In summer a hot day will make it "loose" enough to leak out of the gun, or a spare tube so keep it in a plastic bag
#22 |
Corn head grease for the steering box too.
Just do not put that gl-5 oil in your transmission. NAPA can order some gl-4 for you.
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35). |
#23 |
The JT6 grease is just common grease you use in your grease gun. It should be found anywhere that sells oils. I grease my farm equipment, Bobcat, loader tractor, mowers, ect... with it all the time.
#24 | |
![]() Quote:
True, NAPA can order, at an exorbitant price from an outfit I never heard of. Why would GL4 be more expensive than GL5 when GL4 is missing the Sulphur additive? Two quarts would be well over$100. I'll keep looking. Tom
TomC750 1949 8NV8 Ford tractor 1930 1 Ton White 1941 Mercury Sedan Coupe Last edited by TomC750; 12-19-2024 at 08:02 PM. Reason: afterthought |
#25 | |
![]() Quote:
I am going to put it in the clam shell in several sessions as I about wore out my arm pumping today. Had an air powered gun which went bad, a battery powered one is the way to go now I guess. Tom
TomC750 1949 8NV8 Ford tractor 1930 1 Ton White 1941 Mercury Sedan Coupe |
#26 | |
Don't go nuts for you may overfill it. |
#27 |
Yeah,i'd love to have one of those batt powered grease guns with my carpel tunnel but i would probly over shoot. like to know pump count. Tom.
#28 |
Eastern TN Tom, I also don’t know why 90w gl-4 gear oil is so expensive. OReillys has 140 gl-4 for a much more reasonable price.
#29 | |
![]() Quote:
Something is not right with that price. Oddly, I can't seem to find the gallon size I normally order. I did find a 5 gallon can of CRC/Sta-Lube 85W-90 for $190. https://www.walmart.com/ip/CRC-INDUS...5W90/137341522 |
#30 | |
![]() Quote:
Tom
#31 | |
![]() Quote:
Tom
#32 |
Try millers oil out of England available on Amazon.
Here a link to download their brochure. https://www.millersoils.co.uk/downloads/ |
#33 |
Walmart can be tricky. What they sell on line may not be what they sell in stores. When you do a search, make sure it lists it as in stock at the store you're going to. They are pretty good about keeping accurate inventory.
#34 |
#35 | |
![]() Quote:
You are spot on with your advice in regard to NOT using grease in the springs. When I had finally used up my five-gallon pail of Ford Spring lubricant, I switched to SDTP oil treatment. Nearly the same consistency as the Ford Lubricant and just as easy to install.
#36 | |
![]() Quote:
Tom
