Old 10-09-2024, 11:27 PM   #21
JayJay
Default Re: Electronic cam gear timing tool
I do not have a toolbox on the front so I use a 1-3/8” socket, extension and ratchet to turn the engine over. Maybe I’m unusual, but I’ve found a particular position that makes it easy for me to push on the pin with my left thumb and turn the ratchet with my right hand. Kinda wrapped around the radiator. I can see that this would be much more difficult if I could not use the ratchet, in that case a gizmo of some sort might be handy. Maybe not essential, but handy.
Speaking of which, has anyone modified their toolbox to allow the use of a ratchet?
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 10-10-2024, 04:07 AM   #22
Bruce of MN
Bruce of MN's Avatar
That, plus using the timing indicator and the offset box wrench makes it pretty easy.
Bruce of MN is offline   Reply With Quote
Old 10-10-2024, 05:44 AM   #23
nkaminar
nkaminar's Avatar
JayJay, I had the front mounted tool box too and thought about drilling a hole in the back of it so that I could use the hand crank. I ended up taking it off and selling it. When using the crank the contents would have to be removed and the hand crank would only work in the 9 to 3 o'clock sector.
Old 10-10-2024, 11:06 AM   #24
CarlG
CarlG's Avatar
I have the tool box on the front. I have considered drilling a hole that would line up with the crank hole just for the purpose of turning the crank with a 1-3/8 socket with a 1/2 extension. Especially since I had all that set up before I put the tool box on. The crank starting option wasn't considered in my thoughts. In the 14 years I have owned my pickup, it was started with a crank only once, and that was just to prove that it could be done.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-10-2024, 12:07 PM   #25
JayJay
FWIW, I have the offset crank wrench available from most of the vendors. It has an offset to get around the pulley, but does not have a reversing offset to bring the handle back aft, away from the radiator. I find it difficult to use without scraping my knuckles on the radiator fins.
I looked and Mike's A-Fordable seems to have the one with the double offset, which looks way friendlier to the hands. I think some modification to the one I have is in order.
JayJay
Old 10-10-2024, 04:09 PM   #26
nkaminar
nkaminar's Avatar
Can you bend the handle on the wrench you have to add the extra offsets?
Old 10-10-2024, 04:44 PM   #27
fried okra
Location: Daniel Island,SouthCarolina/Knoxville, Tennessee/Sanibel Island,Florida
I agree Jay Jay.
fried okra is offline   Reply With Quote
Old 10-21-2024, 12:56 PM   #28
Tom A. nh
Now available at Snyder antique auto
https://www.snydersantiqueauto.com/p...=1103848&cat=0
Tom A. nh is offline   Reply With Quote
Old 10-22-2024, 12:34 AM   #29
Hitman
Same tool, same post right? https://www.fordbarn.com/forum/showthread.php?t=343288
Hitman is offline   Reply With Quote
Old 10-22-2024, 12:38 AM   #30
Harrisonmanny87
get a guide manual
Harrisonmanny87 is offline   Reply With Quote
Old 10-26-2024, 05:40 PM   #31
TJMack
I just take the #1 sparkplug out and, with a pen-light, watch the piston. It's quite easy to see when it reaches TDC. But I like Tom's tool. Very innovative.
TJMack is offline   Reply With Quote
