Old 04-14-2011, 08:43 AM   #21
frank55a
Default Re: true 600w oil
Grainger carries both 600 W Super Cylinder Oil and 600 XP 220. You can usually get it overnight or at least within a couple of days.
Cylinder Oil, Extra High Performance, 600 W Super Cylinder Oil, 5 Gallon, Viscosity Index 95, ISO Viscosity Grade 460, Viscosity 460 cSt @ 40 C, Viscosity 30.5 cSt @ 100 C, Flash Point 282 C, Pour Point -9 C), Brown, For Steam Cylinders, Couplings, Bearings Under High Temperature and Load Conditions - $114.35
Gear Oil, High Performance, Mobilgear 600 XP 220, 5 Gallon, Viscosity Index 97, ISO Viscosity Grade 220, Viscosity 220 cSt @ 40 C - $133.45
frank55a is offline   Reply With Quote
Old 04-14-2011, 09:08 AM   #22
mrtexas
mrtexas's Avatar
Originally Posted by Model A Man View Post
I was reading tiny tips for your model A book and on page 106 it states that lubriplate #8 is the same viscosity as "the old time steam oil" know as 600w. I dont know how old the entry in the book is so I am not sure if you can still get it. just a thought. I did find this link
http://www.lubriplate.com/pdf/pds/4_...nd_No.%208.pdf
Lubriplate #8 would be Viscosity 432 cSt @ 40 C or slightly thicker than Mobil 600W but less thick than 680 visc
mrtexas is offline   Reply With Quote
