04-04-2024, 07:16 AM | #21 |
Re: At a loss. 1949 Ford flathead V8
New coil, did hot wire battery to coil. No change. Absolutely cannot figure it out!!
04-04-2024, 07:36 AM | #22 |
Did you check the distributor vacuum advance?
Glenn
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat's Notes Techno-Source for the 1932 thru 1953 Flathead Ford |
04-04-2024, 07:53 AM | #23 |
Check the wire under the distributor plate the points and condenser are mounted on. It might be shorting out somewhere when the advance moves the plate.
