#21 |
If you disassemble them you will find that a scotch Brite pad and brake cleaner are excellent to clean them with.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
#22 |
Location: Daniel Island,SouthCarolina/Knoxville, Tennessee/Sanibel Island,Florida
Anyone use Berryman B-12 fuel injection cleaner to soak plug tips in to clean them?
#23 |
I just turn down the GAV , burn them white with lean mixture, got 2 sets of 3x in the trash because fouling with carbon, 20 miles and they were white and clean, C4 take a hard run to clean.
If fouling to the point of no spark jumping gap give a additional spark gap at the cap to force the spark to jump. First and last pictures are C4,, middle picture are the way my 3x burn with ethonal laced gas. I think many play with heat range to cover mixture problems. the C4 cleaned that much in a 5 mile run. |
#24 |
I well remember when avgas was high in tetraethyl lead and sparkplugs which would build between the electrode insulation and plug casing. We cleaned them at each 100 hourly service using a plug cleaner which blasted sand. This method was not suitable for plugs with platinum electrodes as it eroded them rather rapidly.
For these plugs we took a hacksaw blade, a worn one, and ground down one edge about 2 inches which then fitted well between the 2 electrodes and we physically levered out the lead build-up. No erosion on the electrodes nor insulator. And no change in the gap. Maybe that may help?
I know many things, But I don't know everything, Sometimes I forget things. And there are times when I have a long memory. |
