07-24-2023, 10:26 PM | #21 |
Re: Brake lights not working
07-24-2023, 10:31 PM | #22 |
Yes they do, sorry I didn’t make that clear. On the other hand, you figured that out yourself! Good job!
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
07-24-2023, 10:48 PM | #23 |
07-25-2023, 07:10 AM | #24 |
A team,
You did a good job with the volt meter. It is really good to learn to use them correctly. A lot of electrical problems can be solved with it. It is also good to learn some electrical theory. One is that the electrical circuit is a complete loop. The current starts at the battery and ends up back at the battery. If there is an open part of the loop anywhere the system will not work. Thank you very much for posting the solution. We Barners learn that way, even us old guys who were around in the beginning.
07-25-2023, 08:35 AM | #25 |
A past friend of my mine spent hours checking why his head lights didn’t work, his wife came out and stated do you think both bulbs are burnt out? Tom said light bulbs don’t burn out at the same time……………LOL Tom replaced both head lights!!!!!!!
07-25-2023, 12:58 PM | #26 |
Thanks as always, and hopefully I won't have to post another thread for awhile. 🙏 Here's a couple of pics of the brake lights activated (I forgot to take a picture of the taillights). Ignore the tire cover. That was my father's store that closed in 2001. I don't remember if he painted the graphic on there, or if my sister did it, but he kept it on the spare tire from the late 70s until he started restoring it 15 - 20 years ago. I put it back on there for nostalgia and for my father. |
07-25-2023, 02:15 PM | #27 |
Way back in #4 there was mention of a bad ground. But at least its now fixed.
07-25-2023, 03:35 PM | #28 | ||
07-25-2023, 04:12 PM | #29 | |
07-25-2023, 04:29 PM | #30 |
I ran into an odd electrical problem like this a few years ago while making a Model A streetable that had been an amateur messtoration, complete with the expected shortcomings. A local special interest car place called and asked me to make the dual tail and brake lights work. No matter what their in-house mechanic did, he couldn't get them to work, even after replacing the entire lighting harness and changing bulbs numerous times. I, too, ran into a brick wall for a while until I happened to notice while on my back for the umpteenth time that the underside of the rear fender above me had an odd surface. Not shiny, but kind of crinkly. Sure enough! The beautifully painted rear fender on top was made of FIBERGLASS! No WONDER the rear lights and brake lights wouldn't work! Fiberglass is non-conductive, so there was no grounding ability. I ran a wire from a tailight mounting stand bolt on each side to a good ground spot on the chassis and viola! Let there be light! Another head scratcher solved.
Next time you encounter such a problem with someone else's Model A, ensure that the rear fenders are Henry's STEEL and that the taillight stand has a good ground against the rear fender surface. Marshall |
07-26-2023, 05:57 AM | #31 |
Early electrical systems for houses had one wire with the return path being the ground. Same for early phone systems. Dirt is not very conductive, but if wet and enough of it, it will conduct enough current.
07-26-2023, 07:12 AM | #32 | |
Marshall, good for you. I cant imagine how frustrating that might have been. If that were me, I would still be under the car scratching my head. |
07-26-2023, 10:03 AM | #33 |
m. |
