#21 |
NDNCHF, what is the big button at the bottom of the remote? Do you THINK is will reach the rear window of a sedan?
#22 | |
![]() Quote:
The big button is the emergency flasher. I think it will reach the tudor rear window. A buddy of mine put the same unit in the rear window of his '38 tudor. It works fine. I think it would not reach behind my tailgate because all the sheet metal in between. |
#23 | |
![]() Quote:
Specification (Turn Signal Light) Light source: COB LED Size: 49*65*26mm Waterproof: IP65 Working hours: 4 hours continuous flashing, 70 days stand by. Working Temperature: -10-40C Brightness: 75 Lumen Specification (Remote Control) Light Source: LED Size: 52*50*18.5mm Waterproof: IP65 Working hour: Standby 200 days Working distance: Within 10 meters from the light Soooo, working time while driving should never be an issue. What is an inconvenience is that when you put away the car, the lights gradually lose their charge, so I intend to recharge them before going for a drive or tour. Also, one needs to understand that these lights use RFID (radio frequency) to pair up, so if there are lots of metal between the controller and the lights then they may lose pairing. They were made for bicycles, not autos after all! If they do lose pairing, a simple button push solves it. For my cabriolet and my T touring this is not a problem since they both have soft tops, not a hard body cab. Not a perfect solution, but it's sure worth a try for $65!
Mike Green |
#24 | |
![]() Quote:
#25 |
Ymmv.
Mike Green |
#26 |
#27 |
Awesome!!!!!! I’m ordering some right now!! I also didn’t want to add a tail light but wanted more uninvasive safety! Thank you so much for the info you made my day!!
#28 |
I bought a set for my 29 coupe. Details in another thread. They work great, self canceling.
#29 |
About a month ago I suggested www.carrybright.com for turn signals. They charge four at a time in USB with a cable provided. The turn signal remote also charges with the USB. The LED is very bright. They hold a charge throughout the day, well into the night. The charge seems to last about a week before needing recharging. Costs about $60. on Amazon. Very easy to install. I LOVE THEM and am NOT afraid to drive at night, I also have pre-focused LED lights.
#30 |
The set I bought is from "carry bright" like lrf mentioned above. Very bright in daylight.
#31 |
I just got some. I look forward to trying them out on my roadster.
1924 Model T Coupe 1928 Model A Roadster 1930 Model A Town Sedan 1939 Deluxe Fordor 1945 pickup 1951 Custom convertible |
