12-13-2022, 06:21 PM | #21 | |
Re: 5.5 Snyder head, what else is needed or recommended?
12-13-2022, 06:26 PM | #22 | |
Be more specific - are you suggesting setting the initial timing to 20 degrees BTDC? |
12-14-2022, 12:04 AM | #23 | |
I think this also explains why some people have a problem until they discover that they have a timing cover from a B engine which fires BTDC. |
12-14-2022, 12:12 AM | #24 | |
12-14-2022, 12:56 AM | #25 |
There are two important timing settings on the Model A manual timing system: the initial timing and the total timing. The initial timing is the timing you get when the spark lever is all the way up on the quadrant, i.e., fully retarded. The default setting for the A is 0°, meaning TDC. The default setting for the B is 19°. Since this figure is a positive number, it should be understood to signify 19° BTDC.
Although the default initial timing for the A is 0°, this default was chosen to make it easier to hand crank the engine, or to start it in extreme cold conditions with the straight-weight oil available at the time. Most stock A engines in good shape will start with initial timing as high as 25°. This was demonstrated by Nu-Rex years ago. However, it is useful to retain a low initial timing to give the driver room to back the timing off when under load. The total timing is the timing you get when the spark lever is as far down on the quadrant as you are willing to move it. This is the maximum amount of spark advance available to the engine. For an A engine where the initial timing is 0° and the spark lever is set at 9:00, this is usually about 30° (again, BTDC). Most HC heads decrease the optimal advance at any given point on the torque curve in comparison to the stock head. The most important effect of this is to reduce the total timing. Usually this ends up being around 22-28°. If you exceed the optimal total timing, you get knock. Drivers tend to accommodate this in one of two ways: either they reduce the range through which they adjust the spark lever, or they adjust the initial timing so that it goes below 0°, e.g., -8° (negative numbers signify ATDC timing). When you refer to post #7, the author is talking about his setup in which he set the initial timing to 0° and the total timing to 28°, not 35°. |
12-14-2022, 01:56 AM | #26 |
Not long after the HC head, I blew through an old fiber timing gear. Some have said it could have been due to the higher compression, which I struggle to quite buy into. Others say it is just that it was coincidence. At any rate, I replaced the chewed up fiber gear with an aluminum. |
12-14-2022, 10:33 AM | #27 | |
12-14-2022, 11:18 AM | #28 |
The 5.5 is the only performance head designed by Ford engineering. For model A engine performance increases compression and fuel top the list, the engine can handle in excess of 100 psi compression pressure, stock is 65 psi compression pressure.. fuel? The zenith follows about half the CFM of the engine.. a single Holley 94 or Stromberg 97 downdraft carburetor matches the engine flow almost perfectly.
A performance model A engine is more of what made the stock engine fun to drive, Torque rises with performance improvements. |
