10-19-2022, 01:10 PM | #21 | |
Re: Front Brake Operating Pin Issue
I'll post my finding on the scrapping pin Sat. afternoon. Regards Bill |
10-19-2022, 01:33 PM | #22 |
My LF operating pin had a step worn in it to the point it would hang up and not completely release the LF brake. I have floaters on the front and am thinking the increased side to side freedom of the floater wedge stud causes the pin to rub against the king pin hole.
How else can the pin wear like that? Doesn't the original wedge stud keep the wedges constrained to a purely up and down motion? |
10-27-2022, 08:53 PM | #23 |
Don’t do that. Make sure your backing plate is centered ( holes not elongated ) and tight.
Larry Shepard |
10-27-2022, 10:48 PM | #24 | |
Don't do what? Backing plate is centered, holes not elongated and tight. Last edited by AzBob; 10-27-2022 at 11:06 PM. Reason: Additional info. |
10-28-2022, 04:35 PM | #25 | |
Do his brakes work good? His drums may be turned oversize, as in 11.030" and up. He might need oversize thickness linings. I just read about this this morning. You can find the article on Santaanitaas website. It's by Chris Wickersham "Model A Brakes and Oversize Drums"
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!" |
10-28-2022, 04:48 PM | #26 | |
Brent, Bill, I've looked at the drawings of the backing plate and the dimensions of the tracks etc. 4.619-4.624. The Les Andrews red book gives track location as 1 and 5/16's and 1" from the installed rivets. I assume this is because obtaining the 4.619-4.624 measurements is out of the range of an amateur without some kind of jig to place into the center hole of the backing plate? But, a thread I read somewhere spoke of installing new tracks using enlarged or elongated holes and this could make the track locations less than wonderful... Comments please???
