09-21-2022, 03:37 PM | #21 |
Re: Toe-in adjustment
Guten Abend miteinander.
Today I did a test drive with the tie rod, which was now about 1.5 mm longer. The directional stability is better now, the car no longer wanders left and right, which I had to constantly correct before. The steering is now noticeably heavier while driving, it no longer turns straight ahead out of the curve on its own. I think, this is probably due to the opposing sawtooth profile, as Katy described so nicely in post #16. I would like to thank you all for the numerous and helpful tips!
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
09-22-2022, 08:55 AM | #22 |
The steering wheel return is usually the result of caster. But, maybe the feather edge is what is causing it to not return as it should. [ It should at least try].
Maybe rotating the tires would help. It'll certainly help even out the feather edge. |
