#21 |
I have used the "Battery Tender" for years. My Optima is now 7 years old and still cranks well in my '47. Only problem is locating a new Optima. I have one (6 volt RedTop) on order for a month and counting. They are hard to beat, and for a $250 battery they should!
#22 |
#23 | |
![]() Quote:
Optima advises a very slow charging rate, under 1.5 amps. This battery is connected to my newly installed home generator. As such, the "tender" will be hooked up 24/7.
#24 |
Mike
IF it helps at all, I have a NORCO Genius 10 (???) I have had an a wet cell 6V in the 32 for over a year now, great charger AND I did have to use it to recharge my 6V Red Top Optima once, worked fantastic. I also bought a few of NAPA's 1.5V chargers and two 3.0V chargers they run on sale, both switchable from 6V to 12V and they work well on my wet cell's BUT I have not used it on my Optima. It seem to me NAPA runs them on sale for like $20ish for the 1.5 and $28ish for the 3.0. Good luck |
#25 |
Guys, my day was a wonderful one! A reminder that there are truly good folk "out there". I'd received a battery tender in the mail this afternoon from a fellow Barn member.
The gift, unexpected, was wonderful. However, the thoughtfulness was the best part by far. Yep, my day was wonderful ![]() Thank you, M. E. ![]()
#26 |
