#21 | |
![]() Quote:
#22 |
Exhaust scavenging depends more on the exhaust system than the exhaust valve. The exhaust pulse produced when the exhaust valve opens travels down the exhaust pipe at the speed of sound and reverses when it reaches the end to become a negative pulse traveling up the exhaust pipe to help suck out exhaust. The speed of the engine and the length of the exhaust pipe have to be matched to get this advantage. A diffusing cone at the end of the exhaust pipe will extend the rpm range where scavenging has an effect. Having equal length pipes that combine will allow each cylinder to reinforce the scavenging effect. You can see this on older race cars where the exhaust pipes combine and then there is a diffusing cone.
#23 | |
![]() Quote:
#24 |
What Bob has pictured is a ported AND RELIEVED flathead V8. In them relieving does reduce the compression ratio, relieving is not needed in our A's because in the V8, the valves are not parallel to the cylinders.
#25 |
I think what Jim meant to say is on the model A. block the valves are not sunken like the V8 flathead is the V8 flathead requires relieving for improved air flow the model A. does not as the valve sit on top of the deck
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
