Old 01-03-2022, 12:47 PM   #21
JT FORD
JT FORD's Avatar
Default Re: Should Thread seal tape be used on Pressure Switchs on stop lights?
I installed a new brake switch in my l950 this summer. Go it from NAPA and it came with teflon tape already on the threads in the box. I used it..........
JT FORD is offline   Reply With Quote
Old 01-03-2022, 12:55 PM   #22
Bored&Stroked
Bored&Stroked's Avatar
Yep - I don't see any reason to NOT use Teflon/PTFE thread on a 1/8 NPT brake light switch. It also acts as an "anti-seize" if you need to remove it later on.
Old 01-03-2022, 04:47 PM   #23
Tim Ayers
I would add just be mindful when wrapping the nipple so it doesn't cover the hole.
Old 01-04-2022, 10:19 AM   #24
Ramblin Reck
Ramblin Reck's Avatar
Originally Posted by 40ford View Post
Are you using silicone brake fluid?
DOT3 is what I am using. Not sure if that is silicone.
"Engineers like to solve problems. If there are no problems handily available, they will create their own problems!" ROGER, WILCO, OUT!
Ramblin Reck is offline   Reply With Quote
Old 01-04-2022, 11:04 AM   #25
36coupe
36coupe's Avatar
40 years in the oilfield working with process systems, yes use a sealant for the above reasons.
All Teflon tape is not created equal, the cheap stuff (usually blue cover found in the hardware store is junk. Buy a roll of good Teflon tape and it will last a long time. The biggest issue with tape is too much especially on the first thread.
Pipe sealant paste is probably even better. It takes literally a small smear all the way around to help the seal.
Never put stainless NPT fittings together with out a sealant/ lubricant. They will gall and basically cold weld together, never to come apart again.
Sealing NPT threads is a bit like motor oil discussions in some circles.
36coupe is offline   Reply With Quote
